ᐅ How can I securely mount BILLY shelves on drywall (also known as plasterboard or gypsum board)?
Created on: 24 Sep 2019 08:36
lejubar
Hello everyone, I’m planning to install BILLY shelves from IKEA in my living room, but I’m having issues because the walls are made of drywall.
My question is: How can I securely and permanently mount BILLY shelves on drywall so that they remain stable under load and do not cause damage to the wall?
I know that standard wall anchors are often not sufficient, so I’m looking for specific solutions or recommended mounting methods.
Thanks in advance for your tips and advice!
taudi
24 Sep 2019 14:05
To locate wooden studs behind drywall, it’s best to use a stud finder or a specialized frame and metal detector.
These devices will indicate the wooden sections where you can screw directly.
If you do not find any wood, use cavity anchors or metal anchors that can support higher loads.
Additionally, for greater stability, you can use longer screws, but only if the anchors are designed for them. Always follow the manufacturer’s instructions regarding load capacity and drill bit size!
If your shelf will carry particularly heavy loads, it is also advisable to use multiple anchors per side of the shelf.
lejubar
24 Sep 2019 15:47
taudi schrieb:
For greater stability, you can use longer screws, but only if the anchors are designed for them.
Is there a guideline for the screw length? I have often seen 50 mm (2 inches) recommended, but are 70 mm (3 inches) better?
I don’t want the screw to be too short, but also don’t want to damage the anchor.
RIDAN
24 Sep 2019 16:09
50 mm (2 inches) screws are usually sufficient if the anchors are properly installed.
70 mm (2 3/4 inches) screws do not offer any advantage if your drywall panels are not thicker. It is important that the screw fits perfectly into the anchor and activates it.
lejubar
25 Sep 2019 08:22
Good morning everyone,
I have ordered dowels and plan to install the shelf tomorrow.
If I want to hang more weight or additional shelves on the wall later, does it make sense to add extra reinforcement behind the drywall?
What methods do you know to strengthen drywall without major wall work? Thanks!
taudi
25 Sep 2019 10:34
A simple reinforcement method is to insert so-called backing boards or additional wooden battens behind the drywall, but this requires openings in the wall.
If that is not possible, you can at least distribute the load by mounting a wooden support board behind the shelving rails—for example, an MDF board secured with anchors at multiple points.
This distributes the force across several anchors and reduces the load on individual fixing points.
lejubar
25 Sep 2019 11:56
taudi schrieb:
by mounting a wooden support panel behind the shelf rails
Sounds logical!
Is something like that possible if I don’t want to cut into the drywall? I was thinking of a kind of large board that I could attach directly to the drywall with several strong anchors, and then screw the shelves onto that.
Would the loads then be better distributed across the anchors?
