ᐅ How can I securely mount IKEA Metod wall cabinets on drywall (plasterboard) walls?
Created on: 6 Jul 2021 08:43
Sonnico
Sonnico
6 Jul 2021 08:43
Hello everyone, I want to securely mount my IKEA Metod wall cabinets on a drywall surface. My main concern is that the drywall panels alone are not strong enough to support the full weight of the cabinets, so I am considering how to transfer the load to the metal studs behind them. What mounting methods and anchors have been tested and proven safe for this type of wall with Metod wall cabinets? Are there any special tips on how to position the screws to prevent them from pulling out? I would prefer to avoid complicated coverings or additional wooden substructures if possible. Thanks in advance for your experience and recommendations!
Mekau
6 Jul 2021 09:12
In principle, you should install the cabinets using special metal stud anchors. Alternatively, you can screw long screws directly into the metal profiles, but only if they are accessible behind the drywall. Standard hollow wall anchors do not reliably support the weight of the Metod cabinets.
SUDAN
6 Jul 2021 11:41
For this topic, I recommend a structured approach:
- First, use a metal or stud detector to precisely locate the metal studs behind the drywall.
- The Metod wall cabinets come with hanging brackets that are ideal for screws. You can screw directly into the metal studs if you pre-drill the appropriate holes.
- Use self-tapping sheet metal screws that are at least 4.5 mm (0.18 inches) in diameter and have sufficient thread length to securely grip the stud.
- For additional stability, you can also use metal anchors or heavy-duty wall plugs.
- Be sure to observe the maximum load capacity of the metal studs; if the cabinets will be heavily loaded, additional reinforcement is advisable.
Common mistakes: Standard hollow wall anchors or expansion plugs are often incorrectly used for these loads and can result in premature failure. Wood backing behind the drywall is only necessary if access to the studs is not possible or if the walls unusually lack load-bearing profiles.
letar
7 Jul 2021 14:06
To supplement and clarify the previous advice:
Mekau schrieb:
Standard cavity anchors do not reliably support the weight of Metod cabinets.
This is generally true because drywall alone does not provide sufficient load-bearing capacity. Instead, I recommend:
- Using metal profile anchors designed specifically for metal studs (e.g., C-profile anchors) or appropriate drywall screws.
- Pre-drilling with the correct diameter so that the screw securely engages the metal stud threads without being too loose.
- Checking the load capacity of the metal studs on a case-by-case basis (for example, from the manufacturer or technical datasheets).
SUDAN schrieb:
Common mistakes: Standard cavity or expansion anchors are incorrectly used for these loads and cause premature pull-out.
I fully agree. It is strongly advised against fastening exclusively into the drywall panel.
An alternative, if metal studs are not accessible, is reinforcement with a behind-the-wall wooden batten. However, this is more labor-intensive.
In summary: For Metod wall cabinets on drywall, the safest attachment method is direct screwing into the metal studs using suitable drywall screws or specially designed anchors. A tension-rated wall anchor is advisable to ensure optimal load distribution.
