ᐅ How can I secure Ikea Pax wardrobes to the wall to prevent them from tipping over?
Created on: 29 Aug 2023 18:27
ToelpaHello everyone, I recently purchased an Ikea Pax wardrobe and plan to assemble it at home. Since the wardrobes are quite tall and relatively heavy, I am considering how to safely secure them to the wall to prevent tipping, especially if there are children or pets in the household.
My question is: What are the best options for safely and permanently anchoring Ikea Pax wardrobes to the wall to prevent tipping? Are there specific fastening materials or installation instructions that should be followed? I would appreciate detailed tips, including advice regarding different wall types (concrete, drywall, etc.).
Be sure to use the included wall brackets from Ikea, as they are specifically designed for Pax wardrobes. These can be securely anchored with appropriate wall plugs depending on the wall type (concrete, drywall). Make sure the brackets are properly tightened, and when installing on drywall, be sure to use special cavity anchors.
Regarding securing Ikea Pax wardrobes against tipping, I recommend a structured approach:
- Preparation: Request the exact assembly instructions for your wardrobe model from Ikea. These include the correct wall fastenings.
- Wall type consideration: For concrete walls, standard anchors of 6-8 mm (0.25-0.3 inches) are sufficient; for drywall, choose hollow wall anchors or metal anchors that provide greater support.
- Mounting height: Attach the brackets in areas of the wall that are solid (not too high, not too low).
- Possible additional measures: You can apply self-adhesive anti-slip mats to the bottom of the wardrobe base to further prevent shifting.
- Avoid mistakes: Do not secure only with small screws in drywall or use brackets that are not rated for the wardrobe’s weight.
Summary: Ikea Pax wardrobes can be effectively secured against tipping with the appropriate brackets. Always consider the wall type, use suitable anchors, and firmly screw the brackets to both the wall and wardrobe.
sinhau schrieb:
For concrete walls, standard anchors of 6-8 mm (1/4–5/16 inch) are sufficient; for drywall, use cavity anchors or metal anchors that provide better support. This distinction is crucial for stability. Additionally, I recommend using the original Ikea wall mounts, as they are specifically designed for the construction of the Pax wardrobe. If the wardrobe stands on an uneven floor, check its stability before installation and, if necessary, adjust it with sturdy leveling wedges.
It is also important to verify the module width and height of Pax wardrobes carefully, as larger wardrobes may require more than the standard mounting hardware. In such cases, it is advisable to install additional wall brackets or look for custom solutions.
Finally, a safety note: fastenings should be regularly checked and tightened as needed to ensure long-term safety.
