ᐅ How can I secure Ikea Pax wardrobes to prevent them from tipping over?
Created on: 5 Oct 2024 09:23
Bauna
Hello everyone, I recently bought and assembled several IKEA PAX wardrobes. Since these wardrobes are tall and heavy, I am concerned about safety, especially regarding the risk of them tipping over, for example during earthquakes or accidental bumps, particularly with children in the household. My specific question is: What options are available to securely anchor IKEA PAX wardrobes to prevent tipping? I am looking for recommendations on suitable fasteners as well as tips on correct installation and attachment points (wall types, etc.). It would also be helpful if anyone could share their personal experience on the best way to implement this, to ensure the wardrobes remain stable over time without causing damage to the walls. Thanks in advance for your advice!
Hello Bauna, I would like to add a brief step-by-step guide that can help you securely fix your IKEA PAX wardrobe against tipping over:
1. Check the wall type: As you mentioned, you have a brick wall. In this case, 8mm metal expansion anchors work well.
2. Place the wardrobe against the wall and mark the fixing points, ideally near the top of the wardrobe frame.
3. Drill holes in the wall at the marked spots with a drill bit that matches the anchors (e.g., 8mm SDS drill bit).
4. Insert the anchors until they are flush with the wall.
5. Attach the anti-tip rails or brackets to the wardrobe rails.
6. Position the wardrobe against the wall and screw in the screws with the anchors, using a cordless drill or a sturdy screwdriver without overtightening.
7. If you have multiple wardrobes next to each other, sturdy connecting brackets are recommended. These can be installed inside the wardrobe side panels using small steel brackets and short screws.
8. After installation, gently lift and tilt the wardrobe to check its stability.
Summary: The combination of quality anchors, correct fixing points, and connecting brackets ensures that your PAX wardrobe will not tip over. If you have any specific questions, feel free to ask.
