ᐅ How can I secure BILLY shelves?
Created on: 1 May 2021 08:37
dilige
I currently have several IKEA Billy bookcases in my home and would like to secure them against tipping, especially since I have small children in the household. My question is: How can I effectively and safely fasten or secure Billy bookcases to the wall to prevent accidents without damaging the structure or appearance of the bookcases? Are there any special mounting materials or methods that are particularly recommended? I am also open to creative ideas if standard solutions prove impractical.
Thank you in advance for your helpful tips and experiences!
Joshbe
2 May 2021 09:03
It is important to distribute the load as evenly as possible and avoid placing uneven weight concentrations, as this can increase the risk of tipping.
dunitan schrieb:
Sometimes a combination of small metal brackets at the top and bottom on the back can also be useful.
This matches my experience as well. Additionally, make sure that the screws are inserted deeply enough and firmly into the wall. For uneven walls, spacer washers can help to align the shelf evenly.
For rental apartments where drilling is not possible or allowed, I recommend alternative securing methods such as furniture anchors with backing plates or anti-tip chains, which can be glued or screwed to existing furniture and heavy items.
sihau
2 May 2021 19:46
Summary and Additional Information:
The most important measures to secure BILLY shelves against tipping are:
1. Use the original wall fasteners with suitable anchors for the wall type
2. For drywall (plasterboard) walls: use tested cavity anchors with high load capacity
3. Distribute the shelf load evenly; avoid placing heavy items on the upper shelves
4. Additional reinforcements like metal brackets at the bottom/top can be used to increase stability
5. Avoid standalone placement – combine with other furniture pieces for added stabilization if needed
Joshbe schrieb:
With uneven walls, spacer washers can help align the shelf properly.
This is a very important tip since tension in the shelf frame caused by crooked installation often leads to problems.
Furthermore, I recommend regularly checking the condition and security of the fasteners, especially if there is movement or vibrations in the living space.
