ᐅ How can I secure BILLY shelves?
Created on: 1 May 2021 08:37
dilige
dilige
1 May 2021 08:37
I currently have several IKEA Billy bookcases in my home and would like to secure them against tipping, especially since I have small children in the household. My question is: How can I effectively and safely fasten or secure Billy bookcases to the wall to prevent accidents without damaging the structure or appearance of the bookcases? Are there any special mounting materials or methods that are particularly recommended? I am also open to creative ideas if standard solutions prove impractical.
Thank you in advance for your helpful tips and experiences!
Sinan-meo
1 May 2021 09:52
it is important to always use the supplied brackets or mounts with BILLY shelves to secure them to the wall. These are specifically designed for the frame and ensure a secure connection. Make sure to use wall anchors suitable for your wall type (e.g., concrete, drywall).
If you want to preserve the appearance, I recommend using strong double-sided tape for lightweight furniture only as an additional safety measure, but this does not replace wall mounting. For homes with children, safety is paramount: always firmly fix the shelves to the wall.
COLEBAR
1 May 2021 10:18
Secure the shelves using the original wall anchors.
Use appropriate wall plugs and screws for the wall type.
Otherwise, avoid overloading the shelves.
nonere
1 May 2021 11:06
To secure BILLY shelves, it is essential to use the included metal wall brackets. IKEA recommends a maximum load of 20 kg (44 lbs) per shelf, which is also important for stability in relation to wall mounting.
If the walls are made of drywall, I recommend using special hollow wall anchors with high load capacity. It is also important to choose the mounting height so that tipping when loading is practically prevented. For a clean and refined appearance, the fasteners can be installed behind the shelf frame.
Sinan-meo schrieb:
make sure to use anchors that are suitable for your wall type (e.g., concrete, drywall).
This is crucial because unsuitable anchors cannot withstand the high load and dynamic forces, such as those caused by children.
dunitan
1 May 2021 13:42
As a supplement, if the shelves are placed on a sensitive floor or you want extra safety, you can also use anti-slip mats between the shelf and the floor. These prevent lateral slipping. For wall mounting, I recommend checking the following:
- Wall material (drywall, concrete, wood)
- Load capacity of the anchors
- Position of the screws, ideally through the designated holes on the back of the BILLY shelves
Sometimes, a combination of small metal brackets at the bottom and top on the back can also be useful, especially for large or tall shelves.
If you have children at home, I also recommend not fully loading the shelves with heavy items up to the top edge – this further reduces the risk of tipping.
barEsperan
1 May 2021 15:27
In addition to wall mounting, you can also secure the shelf with heavy-duty adhesive, but only as a supplementary measure, not as a replacement. Additionally, felt pads under the feet improve grip and protect the floor.
