ᐅ How can I safely transport IKEA Metod cabinets during a move?
Created on: 18 Nov 2022 18:23
robertpi33
robertpi33
18 Nov 2022 18:23
I am about to move soon and want to safely transport my IKEA Metod kitchen and storage cabinets. My specific question is: How can I best prepare and pack the Metod cabinets to prevent any damage during the move?
Perhaps you have tips on disassembly, protecting the surfaces, and proper handling during transport. It would also be helpful to know if you recommend certain packing materials or tricks to keep the cabinets stable and prevent shifting while loading and transporting.
Thanks in advance for your advice!
Ramon4
18 Nov 2022 18:57
Hello Robert,
For the safe transport of your IKEA Metod cabinets, I recommend first removing all cabinet doors and internal fittings (such as shelves or drawers). This will help prevent anything from coming loose or getting damaged during transport. Be sure to protect the individual parts, especially the doors, with soft materials like blankets or bubble wrap.
Also, try to transport the carcasses (main cabinet units) in an upright position to minimize stress. If possible, secure them with straps to prevent shifting.
Use sturdy boxes or at least large blankets and tie-down straps to protect everything during transport. Another tip is to clearly label screws, dowels, and small parts, and keep them stored in small bags.
I hope this helps!
farGlen
18 Nov 2022 19:15
Disassemble cabinets, remove doors and shelves, and pad everything well.
Store upright during transport and secure with straps.
Put small parts in bags and label them to avoid problems during reassembly.
robertpi33
19 Nov 2022 08:40
Ramon4 schrieb:
You should protect the individual parts, especially doors, well with soft materials such as blankets or bubble wrap.
Thanks for the tip! How sturdy are the doors actually? Do I absolutely need to use bubble wrap, or are thick blankets sufficient? I don’t have much bubble wrap available.
Also, I’m wondering if I need to completely take apart the cabinets or if it’s enough to just remove the doors and shelves. That would save a lot of time.
Is there a risk that the large cabinet carcasses could be damaged during transport if they’re not disassembled but only well secured?
Ramon4
19 Nov 2022 09:17
robertpi33 schrieb:
How sturdy are the doors? Do I absolutely have to use bubble wrap, or are thick blankets enough?
The doors are quite delicate, especially the decorative fronts, which can scratch easily. Thick blankets are usually sufficient if they are well padded between furniture pieces and there’s no contact with hard surfaces. Bubble wrap is of course better but not absolutely necessary.
robertpi33 schrieb:
Is there a risk that the large cabinets might get damaged during transport without disassembly, if they are well secured?
Yes, especially if they are transported lying down or if they shift around. The stress can cause holes, fittings to come loose, or dents. Transporting them upright and securing them well is really important. Fully disassembling is safest but not always necessary if you are careful.
kemeo68
20 Nov 2022 13:52
Ramon4 schrieb:
If possible, you can secure them with straps to prevent shifting.
Securing is definitely correct, but I find that it often only offers partial protection. Especially the IKEA Metod series is designed to be easy to assemble, but it often lacks stability during transport.
If you only use straps, you risk the cabinets bending or the moldings breaking due to movement. In my experience, the cabinets are better protected when packed in sturdy transport boxes or at least shielded with wooden panels to prevent stress on individual parts.
For those who want to avoid the hassle, I recommend fully disassembling the cabinets. It might be tedious, but I would rather invest time than deal with expensive repairs afterward.
Also, I think the myth that "just securing well is enough" is repeated far too often. Transport always involves stress, and flatpack furniture is not made to withstand rough handling.
