parreinhol1 Jun 2022 08:37Hello everyone,
I recently purchased an Ikea Besta system to store various items. My question is specifically about safely storing heavy objects—such as TVs, heavy books, or larger decorative pieces.
I understand that the Besta units are made of particle board, which can bend or even get damaged quickly under excessive weight. I’m also concerned about overall stability when storing heavy loads over a longer period, especially if the cabinets are not secured to the wall.
Are there particular tips, materials, or reinforcements you would recommend? Should individual shelves be reinforced, or is it better to place heavy items at the bottom of the cabinets?
Any advice on securely anchoring the entire Besta system to the wall to prevent tipping would also be appreciated.
Thank you in advance for your experiences and recommendations!
parreinhol schrieb:
Are there any specific tips, materials, or reinforcements you would recommend? I completely understand, as I was also worried that heavy items might damage the Besta shelves. To address this, I reinforced the shelves by adding a thin multiplex plywood board. Multiplex plywood is a bit stronger than the original particleboard and distributes the weight more evenly.
The system should always be secured to the wall, especially for the reason that it can tip over, particularly when heavy items are stored on top. This makes me feel much safer overall.
parreinhol schrieb:
Is it better to reinforce individual compartments specifically, or should heavy items be placed at the bottom of the cabinets? Personally, I always stored heavy items at the bottom because it not only improves stability but also makes access easier. In the end, it’s more practical and helps protect the furniture.
I hope this is helpful — but for heavier loads, I would still advise caution and consider additional reinforcements.
Hello parreinhol,
I would like to add that Ikea Besta modules are designed for moderate loads. According to the manufacturer, the maximum load capacity of a shelf usually ranges between 10 and 15 kilograms (22 to 33 pounds), depending on the shelf and its design. To safely store heavy items, I recommend the following points:
- Always place heavy items on the lower shelves to keep the center of gravity low and avoid tipping.
- Use additional base plates made of wood or metal placed under the shelf to better distribute the weight.
- Reinforce the shelves with special shelf brackets or by inserting custom-sized panels made of plywood or MDF.
- Securely fix the entire system to the wall using appropriate anchors and screws – this is essential to prevent tipping.
- If you have very heavy loads, I suggest considering the use of heavy-duty shelving, as Besta is primarily a residential furniture system, not an industrial shelf.
If you have the Besta system with glass sliding doors or similar attachments, make sure to also observe the maximum load capacity, as these affect the overall structure.
I hope this helps, as safety should always come first. It’s better to plan a bit more carefully to ensure long-term enjoyment of your furniture.
parreinhol schrieb:
I am aware that the Besta modules are made of particleboard, which can quickly bend or even damage the shelves under excessive loads.You are absolutely right, as the material is a key factor for load-bearing capacity. Ikea Besta uses standard particleboard, which is stable enough for everyday use but cannot handle high constant loads. Therefore, here is a detailed approach I recommend for safely storing heavy items:
- First: Check the exact load capacity of your modules using Ikea documentation or product data sheets. This may vary for older models.
- The shelf boards are the weakest point. You can have birch plywood sheets cut to the exact dimensions of your shelves with a thickness of at least 18 mm (0.7 inches) and simply place them on top. These significantly reduce bending stress.
- As an alternative to plywood, there are reinforced particleboards with longitudinal supports or dense laminated structures, but plywood is generally easier to work with.
- For wall mounting, use special heavy-duty anchors and screws appropriate for the wall type (e.g., concrete, drywall). For drywall, always screw into the studs, otherwise the bracket will not hold.
- Optionally, you can reinforce the inside of the modules with metal profiles screwed vertically between the side panels and shelves. This adds more stability to the overall construction.
- Arrange your items to avoid concentrated loads (e.g., point loads). Distribute heavy weights evenly over a broad area.
I would be interested to know exactly how heavy your “heavy items” are and what dimensions your Besta modules have. That would help to give you more precise advice.
I hope this helps with your planning. You can definitely make Besta units more stable if you understand and apply the technical details correctly.
