ᐅ How can I safely disassemble Ikea Metod cabinets for a move?
Created on: 28 Feb 2023 14:13
mikopar
Hello everyone, I am planning to move soon and want to carefully disassemble my Ikea Metod kitchen cabinets without causing damage. My goal is to take all parts apart in a way that allows them to be reassembled later easily and without any material loss. I am especially interested in safe handling tips for the fittings and how to avoid broken dowels or damaged cabinet components. Does anyone have experience or recommendations on a systematic approach for disassembly, the best tools to use, and common mistakes to avoid? Thanks in advance for your detailed advice!
jan10
1 Mar 2023 11:47
It is best to remove screws using a Phillips PH2 screwdriver. Simply turn cam connectors, do not pull. Carefully pry off back panels, avoid using excessive force. Load top and bottom panels, doors first. Pack disassembled parts!
KIN42
1 Mar 2023 14:59
Additional information: When dismantling, be sure not to notch or damage any chipboard edges. Often, pulling on the connectors causes the material to fray. Using a small lever tool with a plastic or wooden spatula can help prevent this. For the cam connectors, it is advisable to turn the metal part with a suitable screwdriver until the connector releases, then separate the joint. This significantly reduces the risk of damage.
bupar
1 Mar 2023 17:28
mikopar schrieb:
My goal is to disassemble all parts in a way that allows them to be reassembled later without any material loss or difficulty.
An important addition: It is best to document every joint and step during disassembly. A short photo series or detailed notes are extremely helpful for reassembly. Systematically packing small parts into labeled bags also reduces stress and helps maintain the furniture’s structure. This way, you avoid mixing up components like cam connectors or screws.
gesar32
2 Mar 2023 08:37
In conclusion, I recommend paying special attention to the handling of the side panels and shelves when disassembling the cabinets. The side panels are usually secured with cam connectors, which should be carefully unlocked. To preserve their durability, the disassembly process should be slow and gentle, avoiding any force. Temporarily storing sensitive parts on a soft surface also helps prevent damage. If you follow these guidelines, your Ikea Metod cabinets will be well prepared for transport and reassembly.
