ᐅ How can I safely disassemble and reassemble Ikea Metod cabinets when moving?
Created on: 2 Oct 2024 10:12
karhau
Hello everyone, I am planning to move soon and want to carefully disassemble my Ikea Metod kitchen/cabinet modules and correctly reassemble them at the new place. My question is, what methods have proven effective for storing both the furniture and the fittings (dowels, screws, fittings) in a way that keeps them undamaged and well-organized? I am concerned that the joints might get damaged during disassembly, making reassembly more difficult. I am also interested in how you keep track of the individual parts, since Metod combines various different doors, drawers, and shelves. Are there any special tips or tools to make the disassembly and reassembly process efficient and error-free? I would appreciate practical advice!
For adjusting the doors on Ikea Metod cabinets:
- Hinges usually have several adjustment screws (horizontal, vertical, depth). Start with the vertical adjustment to set the height.
- Then adjust horizontally so the door aligns flush with the cabinet frame.
- The depth (closing pressure) is adjusted last to ensure the door closes properly without sticking.
Patience is important here, as multiple small adjustments may be necessary. Use a small screwdriver and check the door’s movement and the gap after each adjustment.
Jensson’s tip is very helpful! I’d like to add that if doors are not properly aligned, it can sometimes help to use a spirit level to ensure everything is straight. And if the hinges are too tight, you can slightly loosen the screws and try fine adjustments. Above all, it is important to stay calm and work systematically to ensure everything functions well later on.
