ᐅ How can I safely disassemble and reassemble Ikea Metod cabinets when moving?
Created on: 2 Oct 2024 10:12
karhau
Hello everyone, I am planning to move soon and want to carefully disassemble my Ikea Metod kitchen/cabinet modules and correctly reassemble them at the new place. My question is, what methods have proven effective for storing both the furniture and the fittings (dowels, screws, fittings) in a way that keeps them undamaged and well-organized? I am concerned that the joints might get damaged during disassembly, making reassembly more difficult. I am also interested in how you keep track of the individual parts, since Metod combines various different doors, drawers, and shelves. Are there any special tips or tools to make the disassembly and reassembly process efficient and error-free? I would appreciate practical advice!
flo-Theres2 Oct 2024 14:17A small addition: To safely dismantle the Metod modules, it is advisable to strictly follow the order during disassembly. Start with the doors and drawers, carefully label screws and fittings, and store them separately for each cabinet. Use appropriate tools during removal to avoid damaging connectors (e.g., cam locks). Especially for the doors, I recommend thoroughly documenting the hinges and fastenings, as they are more complex than the carcasses. Less experienced individuals should not hesitate to consult the IKEA manual multiple times throughout the reassembly process.
Here is a simple step-by-step guide for disassembling and reassembling Metod cabinets:
- Preparation: Clear the space and ensure good lighting.
- Empty the cabinet and remove the doors along with the hinges.
- Take out the drawers.
- Remove the shelves.
- Loosen the cabinet frame fasteners using appropriate tools (ideally a cordless screwdriver with a torque limiter to avoid damaging the screws).
- Collect screws and dowels sorted in small, labeled bags.
- Take photos of important connection points and hinges to have a clear reference later.
When reassembling, the process is essentially the reverse:
- First, assemble the cabinet frame.
- Insert the shelves and drawers.
- Mount and adjust the doors.
A common mistake is overtightening screws or incorrectly inserting dowels, which can compromise stability—this should be carefully avoided.
gasidney schrieb:
Most importantly: Collect all screws, nuts, and small parts in labeled bags or small boxes That's a good tip, thanks! Do you use special containers for that or just freezer bags? And how do you best keep the parts organized, especially during the chaos of moving? Some small parts are really tiny.
Usually, it is sufficient to use small zip bags or so-called screw bags that can be labeled. I always labeled them with tape and a piece of paper. It is important to attach the bags directly to the corresponding furniture parts or to label them, so nothing gets mixed up during transport. For added security, these bags can also be placed in a sturdy box with several compartments to prevent them from getting lost.
A small note on stability: After reassembling the Metod cabinets, it is important to check and tighten all screws again, as they can sometimes loosen slightly during transport. It is also advisable to carefully align the furniture after assembly – Metod often offers various adjustment options on the feet and hinges. In short: Patience and attention to detail pay off not only during disassembly but also during reassembly.
Jensson schrieb:
Take photos of important connection points and hinges to have a clear reference later One question regarding this: Do you also record videos, or is a photo series enough for you? I’m curious whether moving images actually help during the reconstruction or if they just take up extra time.
