ᐅ How can I safely disassemble and reassemble Ikea Metod cabinets when moving?
Created on: 14 Jun 2018 19:23
poultu
poultu
14 Jun 2018 19:23
Hello everyone, I hope to find experienced people here in the forum who can help me with moving Ikea Metod kitchen cabinets. My specific issue is the following: I will soon need to dismantle my existing Metod cabinet in the kitchen, transport it safely, and then professionally reassemble it. Of course, I want to avoid any damage to the carcasses, fronts, or connecting hardware. What steps are recommended to disassemble the cabinet as gently as possible? Are there any special tips on how to label or securely store fittings and screws? And what should I keep in mind when reassembling to ensure stability and prevent any wobbling? I am especially interested in firsthand experiences — how have you handled this yourselves, and what should you definitely pay attention to? I would appreciate detailed advice and perhaps recommendations for tools or aids that can make the process easier. Thank you very much!
NUGRANT
14 Jun 2018 21:04
Hey poultu, great question! I’ve disassembled and moved my Metod cabinets twice now, and it works really well if you keep a few things in mind 🙂
- First, remove all internal drawers and shelves to protect the fronts and reduce weight!
- Collect screws in small bags or containers and label them so you know exactly which parts they belong to.
- Mark the holes in the carcasses, for example with tape, to avoid confusion during reassembly.
- Very important: when disassembling, loosen the fittings carefully without applying force, as some parts are delicate.
- It’s best to use a cordless drill with adjustable torque so you can loosen and reinsert screws with controlled force!
One last tip: when transporting the carcasses, avoid lifting them by the sides; instead, support them from underneath or at sturdy points to prevent damage.
Good luck, you’ll do great! 🙂
Eugeneki
15 Jun 2018 10:37
Hello poultu, I would like to contribute as clearly and structured as possible.
For the safe dismantling of IKEA Metod cabinets, the following procedure is recommended:
- Before removing the fronts, empty all compartments completely and remove the interior fittings to reduce weight and the risk of breakage.
- Carefully inspect the fittings (cam locks, eccentrics, pins) and note their positions – for the Metod system, the eccentrics are particularly important for stability.
- Collect all screws and small accessories in numbered containers or systems to ensure proper organization.
- When detaching the fronts, carefully loosen the fixing points, as rough handling can quickly cause damage.
- A cordless drill with adjustable torque is advisable to loosen and re-tighten screws in a controlled way.
- Transport the cabinets preferably disassembled and with fronts open to protect them; transport in a lying position often causes less damage.
- When reassembling, make sure all eccentrics are properly screwed in and adjustments are made so that the fronts fit precisely and the doors close correctly.
Finally, a practical tip: take photos at every step before dismantling. These are extremely helpful during reassembly, as you can clearly see how everything was installed.
I hope this helps you.
Luchen
15 Jun 2018 19:56
Eugeneki schrieb:
Take photos at each step before disassembling.
Very important! Photos help keep track of everything.
- It’s best to put screws in small bags attached directly to the component or secure and label them with tape.
- When removing panels, unhook them carefully without forcing anything.
- Tools: cordless drill with the appropriate bit and torque control.
This will save time and prevent stress during reassembly.
Connor
16 Jun 2018 09:14
It’s interesting how many people here talk about cordless screwdrivers and markings – it almost sounds like the IKEA Metod cabinet is a complex high-end piece of furniture. In reality, the system is quite sturdy, and I’ve often noticed that many people make things more complicated than necessary when it comes to “correct” disassembly.
My view: Just remove the doors, unscrew the panels, and pack the carcasses separately. Of course, no one should handle the wood roughly, but all the detailed photos and meticulous labeling? In my opinion, that’s often overestimated.
Also – if there’s a bit of wobble or minor cosmetic imperfections when you rebuild, in practice, it usually isn’t a big deal. The main thing is that the cabinets stand stable and function properly.
Of course, if you want to do it perfectly and without any damage, Eugeneki’s method and similar approaches are great. But you shouldn’t underestimate practical craftsmanship and pragmatism.
