ᐅ How can I retrofit soft-close hinges on IKEA Platsa doors?
Created on: 20 Jan 2020 08:34
kopoplo
kopoplo
20 Jan 2020 08:34
Hello everyone, I have a question that hopefully someone in the forum can answer: How can I retrofit soft-close hinges on IKEA Platsa doors?
I have several Platsa units and would like to make the doors a bit more convenient, as they currently don’t have soft-close and tend to close quite loudly. I’m aware that Platsa products are generally not sold with soft-close doors, at least not officially.
My idea is whether there is a retrofit solution where I can either replace the existing hinge with a soft-close hinge or if there are special add-on dampers that can be installed separately.
It’s important for me to find the simplest solution possible without major modifications or significant changes to the cabinet or door, as I don’t want to spend a lot of effort.
Has anyone here already had experience retrofitting the soft-close function to Platsa doors and can provide tips on suitable technology, installation, and possible pitfalls? I would really appreciate any helpful answers!
TEBILO
20 Jan 2020 10:17
kopoplo schrieb:
How can I retrofit soft-close on IKEA Platsa doors?
Retrofitting soft-close on IKEA Platsa doors is possible, but there are some important details to consider to ensure a practical and stable result. Basically, there are two options:
- Install complete hinges with integrated soft-close functionality
- Add separate dampers mounted next to the hinge
The standard hinges on Platsa are relatively simple and do not have the typical built-in soft-close feature — they are fairly flat and designed for easy installation.
I recommend first checking the exact type of hinges you have. If you have IKEA Metod hinges (which is usually not the case with Platsa), there are compatible soft-close inserts available. However, Platsa typically uses its own hinges.
My personal approach, which has worked well, is as follows:
1. Remove the old hinges
2. Choose hinges that include soft-close and are as compatible as possible with the existing drill holes (e.g., from third-party suppliers specifically made for IKEA)
3. Install without major cabinet modifications
An alternative method is to mount small additional dampers (also called “door buffers”) that you can attach to the side of the cabinet frame. These might be slightly visible but do cushion the door closing quite effectively.
Common pitfalls include:
- Drill holes not aligning perfectly, requiring new holes
- Door weight and hinge compatibility
- Door material and thickness affecting installation options
Just to be sure, which hinges are currently installed on your doors? Knowing this makes it much easier to find suitable soft-close options.
If you can provide that info, I can also recommend manufacturers or sources.
Jamalli
21 Jan 2020 14:03
TEBILO schrieb:
If you have the IKEA Metod hinges (which is usually not the case with Platsa), there are compatible soft-close fittings, but Platsa typically uses its own hinges.
This is an important point! Many users confuse Platsa with Metod, which actually means different types of hardware. This raises the question of whether it really makes sense to convert to other hinges or if it’s better to use separately mounted dampers.
I think it’s important to also consider the mechanical requirements: the soft-close function must not only prevent slamming but also ensure the door closes reliably and remains easy to adjust. Cheap add-on dampers can reach their limits here and may cause inconsistent door closing.
Additionally, the amount of work involved in changing hinges should not be underestimated, especially if the drilling holes don’t match. It would be interesting if anyone has ever found soft-close hinges specifically for Platsa, whether as an original or third-party product — as that would be the technically cleanest approach.
My recommendation: if possible, try an add-on damper first and observe the effect. If that is satisfactory, it would be the simpler and less invasive solution.
feklo
22 Jan 2020 18:26
kopoplo schrieb:
How can I retrofit soft-close hinges to IKEA Platsa doors?
Here is a practical guide for adding soft-close functionality to IKEA Platsa doors:
- Step 1: Assessment
First, check the existing hinges to see if they have standard mounting holes (usually Ø 35mm (1.38 inches) for the hinge cup) and note the door thickness.
- Step 2: Choosing the soft-close option
a) Soft-close hinges: There may not be direct IKEA replacement parts specifically for Platsa. However, third-party suppliers often offer compatible options, such as "Blum ClipTop" soft-close hinges.
b) Additional dampers: Small, separate dampers can be installed either inside the cabinet carcass or on the door itself to slow down door closing.
- Step 3: Tools & preparation
You will need a cordless drill, possibly a drill with hole saw bit (if new hinges require drilling), tape measure, and screwdriver.
- Step 4: Installation
For soft-close hinges, remove the old hardware, adjust or drill mounting holes as needed, and work precisely to avoid warping the door.
- Step 5: Adjustment & testing
Fine-tune the new hinges or dampers carefully to prevent malfunction.
Common mistakes:
- Insufficient stability with doors that are too thin
- Incorrect placement of dampers
- Improper adjustment leading to irregular closing behavior
My advice: Since Platsa often comes with basic hinges, adding separate dampers is usually the easiest way in. If you are more confident with technical work, replacing the entire hinge can provide the highest comfort but requires accuracy.
I’m happy to recommend specific models if you provide exact hinge specifications or door measurements.
