ᐅ How can I retrofit IKEA PAX wardrobes with LED lighting?
Created on: 29 Dec 2024 21:43
sirigu
Hello everyone, I want to retrofit my Ikea Pax wardrobe with LED lighting and I’m unsure about the best approach. Specifically, I’m interested in solutions that can be neatly integrated into the wardrobe, so they are as discreet and functional as possible. I’m looking for recommendations on suitable LEDs (rail lights, bars, strips), safe connection options (preferably without major electrician work), and the most effective ways to control the lighting (rocker switch, motion sensor, remote control, or smart app integration). I’m also seeking advice on cable management, as I don’t want to damage the existing wardrobe, as well as information on whether additional power sources are needed and how to install them discreetly. Has anyone completed a project like this or knows good solutions I should consider? Thank you in advance for all ideas, tips, and experiences!
Palenar
1 Jan 2025 11:37
sirigu schrieb:
Does anyone here use specific models of motion sensors that work well inside an Ikea PAX wardrobe?
I can recommend the Aqara Motion Sensor, which is compatible with ZigBee systems and integrates well into smart home setups. It reliably detects motion just a few centimeters (inches) in front of the door and is compact enough to be discreetly mounted inside the PAX wardrobe.
sirigu schrieb:
I heard that some LED strips have issues with warm white LEDs because they are not as bright—is that true?
That used to be more of an issue, as warm white LEDs are often designed for a cozy atmosphere and emit somewhat less light than cool white versions. However, modern LED strips usually offer good brightness, especially when equipped with high-quality chips (e.g., 2835 or 3528 LED chip types). The CRI (color rendering index) value also matters to ensure colors appear natural.
sirigu schrieb:
With possible smart control, I am currently looking at simple options like Hue-compatible or ZigBee lamps that can be connected in series.
The Philips Hue Lightstrip Plus is a reasonable choice if you’re willing to invest a bit more. These light strips are flexible and app-controllable. Installing them inside the PAX is possible but requires careful planning in terms of power supply and space for the network hub. Alternatives include more affordable ZigBee LED controllers with separate power supplies and motion sensors, which can be integrated via Home Assistant or similar platforms.
If you want a simple plug-and-play solution, I would recommend classic LED strips with a motion sensor, even though these won’t be as smart.
