ᐅ How can I retrofit Ikea Pax doors with a soft-close mechanism?
Created on: 16 Oct 2023 08:12
Manasse55
Manasse55
16 Oct 2023 08:12
Hello everyone, I want to retrofit the existing doors on my Ikea Pax wardrobe system with a soft-close mechanism. My doors are the standard wooden framed doors, not sliding doors. It is especially important to me that the retrofit is as simple as possible and requires minimal modification to the door profiles. I also prefer a system that provides cushioning when closing to prevent slamming. Can anyone offer advice on which soft-close systems are compatible or the best way to convert Pax doors? Are there specific hinges or damping components that are recommended? Thanks for any tips and experiences!
Aimee
16 Oct 2023 09:35
Ikea offers soft-close hinges that can be easily replaced. Alternatively, damping buffers that stick to the frame can be used. Both options are straightforward and effective.
LUISABEL
16 Oct 2023 10:58
Regarding the question of how to retrofit IKEA Pax doors with a soft-closing system, it is possible to replace the original hinges with soft-close models, which are also offered by IKEA. These hinges are specifically compatible with the Pax series and can be installed on the doors without significant modifications. Alternatively, damping buffers can be attached to the door frame if a full hinge replacement is not desired. When choosing the components, it is important to pay attention to the correct size and installation method, as well as ensuring that the doors are not adversely affected or become too loose.
Josefane
16 Oct 2023 11:22
LUISABEL schrieb:
Alternatively, cushioning pads that can be glued onto the door frame are an option if a complete hinge replacement is not intended.
That sounds practical, but does anyone have experience with whether these adhesive pads hold up in the long term, or if they might cause other issues such as sticking or misaligned doors? I ask because retrofitting with new hinges is more labor-intensive but probably more reliable.
lyndon
16 Oct 2023 12:47
Retrofitting a soft-close system for Ikea Pax doors is most reliable using the original hinges from Ikea. The damping mechanism is firmly integrated into the hinge itself, which significantly reduces the risk of malfunctions. Adhesive damping pads are a quick temporary solution, but depending on the surface and load, they can come loose or lose effectiveness. It is important to remove and reinstall the door to precisely adjust the hinges and optimize the damping.
Manasse55
16 Oct 2023 14:03
Josefane schrieb:
That sounds practical, but does anyone here have experience with whether these adhesive bumpers hold up in the long term, or if they might cause other issues, such as sticking or misaligned doors?
Thanks for raising that point; it’s exactly one of my concerns. I know that with doors, unevenness can sometimes occur after attaching adhesive bumpers, which can affect closing. Does anyone have specific experience with the long-term performance of these adhesive bumpers on Ikea Pax wardrobes? I’m wondering if the effort of replacing the hinges might actually be the better option.
