ᐅ How can I retrofit soft-close drawers to Ikea Metod kitchen cabinets?
Created on: 21 Jan 2023 19:37
ixnetra
ixnetra
21 Jan 2023 19:37
I am currently upgrading my Ikea Metod kitchen and would like to retrofit the drawers with a soft-close feature. My specific question is: How can I retrofit Ikea Metod soft-close drawers if I have previously installed standard drawer slides without damping?
I am especially interested in practical tips regarding the compatibility of soft-close mechanisms, whether I need to buy special replacement parts or complete drawer slides, and how complex the installation is compared to replacing the entire drawers. Are there any experiences with third-party components that work well for retrofitting?
I would greatly appreciate detailed advice so I can plan the project properly. Thank you in advance!
Kenon70
21 Jan 2023 20:18
ixnetra schrieb:
How can I retrofit Ikea Metod soft-close drawers if I currently have regular slides without damping installed?
You need to replace the existing slides entirely with the Metod soft-close version. The damping mechanism is usually built-in and cannot be added separately. It’s best not to try to modify or add parts individually.
Surela
22 Jan 2023 08:42
Kenon70 schrieb:
You need to completely replace the old drawer slides with the Metod Soft-Close version.
That is basically correct. However, there are a few details to keep in mind when retrofitting the Ikea Metod Soft-Close drawers.
First: Ikea’s Soft-Close slides are not available as separate damping components but always come as a complete set with the rails. Therefore, the existing slides must be removed. These slides are designed specifically for the Metod system, which makes installation and removal easier if you have the right tools.
Second: Installing the new Soft-Close slides requires some care regarding positioning and alignment, as the damping only works properly when the rails are mounted perfectly straight. Any unevenness or improper fixing can affect the Soft-Close function or cause increased wear.
Third: If you want to keep your old drawer fronts, this usually isn’t a problem as long as the attachment points for the fronts on the organizer profiles remain compatible. Ikea is quite modular in this regard.
Regarding your question about third-party components: Some manufacturers offer universal Soft-Close kits that can be installed on standard metal or wooden drawers, but most of these are not as precisely matched as Ikea’s own systems. This can result in a more complicated installation or a different opening experience.
If you like, I can also provide a rough step-by-step guide for the replacement. Just let me know which models you have exactly and whether you already have the necessary tools ready.
gesar32
22 Jan 2023 12:59
Surela schrieb:
The soft-close drawer slides from Ikea are not available as a separate damping mechanism, but always come as a complete set with the rails.
That sums it up precisely. Additionally, I would like to add:
- The soft-close slides for Ikea Metod drawers are specifically sized (width and height), so you should definitely measure the width of your existing drawers before purchasing.
- When installing, be careful not to overtighten the screws, as the aluminum rails are sensitive to excessive pressure.
- Proper preparation is important: remove the drawer, take out the old slides, carefully position and secure the new ones.
Retrofit of individual mechanical dampers (as is possible with furniture from other manufacturers) is not technically intended here and is questionable in terms of durability and functional warranty. Replacing the entire set of rails is the best practical solution.
I also recommend buying new drawer slides that include the dampers for better results instead of makeshift fixes. This ensures long-lasting performance.
