ᐅ How can I retrofit IKEA Metod drawers?
Created on: 25 Oct 2024 13:07
kefotau
kefotau
25 Oct 2024 13:07
Hello everyone, I am planning to add extra drawers to my existing IKEA Metod kitchen to better utilize the storage space. However, it is an older Metod system, and I am not sure if I can install the new drawers directly or if modifications are necessary. Specifically, I would like to know which components I need (drawer boxes, side panels, drawer slides, etc.) and whether the existing base cabinets can simply be upgraded, or if there are certain limitations due to the current cabinet design. It would also be helpful to know if there are official retrofit kits from IKEA, or if it is better to use third-party suppliers. Does anyone have experience retrofitting Metod drawers in older kitchen models and can offer installation tips? Thanks in advance!
neoren
25 Oct 2024 14:23
For the retrofit, you need new drawer boxes including runners that are specifically designed to fit Metod. Make sure your cabinet carcass is prepared accordingly, either with the correct pre-drilled holes or at least with the option for modification. Older models may have different drill holes, so measuring is necessary in those cases. IKEA itself offers retrofit parts, but usually only complete inner drawer sets. Third-party suppliers are particularly useful when custom dimensions are required.
Domau0
26 Oct 2024 09:41
Retrofitting IKEA Metod drawers in older kitchens can be somewhat complex, as IKEA has made small design changes over the years that affect compatibility. In general, you should consider the following points:
- First, check whether your cabinet carcasses have the standard drill or mounting points for drawer slides. Older models often have fewer or non-standard holes.
- There are mainly two types of drawer slides: the classic undermount (soft-close) and the runner rail version. Older carcasses often lack the appropriate runner rails and will need to have them installed.
- IKEA usually uses ‘Richel’ hardware for Metod (also available in Tip-On or soft-close versions) that IKEA supplies for retrofitting. If you want to use the original Metod boxes, make sure the drawer bottom can be mounted low enough for the lever mechanism to operate properly.
- If your carcasses are from an early Metod series, it is worthwhile to use a caliper and compare the measurements with IKEA’s official documentation or assembly instructions to see if the standard slides will fit. Minor modifications with drilling or brackets may then be necessary.
- Third-party suppliers offer versatile and adjustable drawer slides that allow compensation for different thicknesses and heights. However, this can lead to compatibility issues with the original drawer fronts, as precise dimensions may vary.
Have you already checked the manufacturing year or version of your Metod carcasses? That information would be helpful to more accurately assess compatibility.
klo61
26 Oct 2024 19:33
I can offer some practical advice based on my experience. Many people underestimate at the beginning how important it is to take accurate measurements and then choose the right drawers.
Domau0 schrieb:
First, check whether your carcasses have the standard drilling or mounting points for drawer slides.
This is really the most important step. If the holes are missing or positioned differently, you will almost always need to drill new ones. It’s best to pay attention to the hole spacing here – IKEA usually uses the 32mm system, which means holes spaced 32mm (1.25 inches) apart vertically.
Even though the Metod drawers are relatively sturdy, you should ensure that the fronts and boxes are not too heavy for the slides. IKEA’s soft-close drawers are really good; you notice the difference immediately.
An alternative, if you can’t get the original parts, are more modular drawer boxes from third-party suppliers that are easy to adapt. Sometimes their quality is even better, especially if you want to build something more customized.
If you like, I can also send you a checklist that I created when I expanded my kitchen.
RENMA
27 Oct 2024 07:16
In summary, the following steps are advisable for retrofitting IKEA Metod drawers on older carcasses:
- Verify the carcass measurement system and existing drill holes (possibly check the 32mm system)
- Select compatible drawer boxes and drawer runners (IKEA original or equivalent third-party options)
- Consider the mounting points of the front panels, as these may have changed over the years
- Possibly re-drill and adjust the side panels (with caution, precise drilling is required)
- Check the load capacity of the drawer runners, especially for larger drawers
Regarding your question about official retrofit kits: IKEA generally offers complete sets for Metod but does not provide separate retrofit kits specifically for older models. The best approach is to measure the old carcasses accurately and compare them with the current dimensions of IKEA drawer products. Third-party suppliers can be a good alternative, offering more flexibility. A recommendation: use a spirit level and clamps during installation to distribute the load evenly and align the drawers precisely.
