ᐅ How can I retrofit IKEA Metod drawers with soft-close mechanisms?
Created on: 3 Apr 2024 08:37
Mate1
Hello everyone, I am looking for a way to retrofit soft-close functionality to my already installed IKEA Metod kitchen drawers. So far, the drawers don’t have any dampers, so they often close with a bit of force. Is there a product from IKEA or a compatible third-party solution that allows me to easily upgrade these drawers with a working soft-close feature without having to replace the entire drawer slide system? I have heard about a type of retrofittable damper module, but I’m not sure how exactly it works and if it is normally possible with Metod. I would really appreciate tips or even detailed instructions, especially if it’s possible to avoid using tools or drilling. Thank you in advance!
Mate1 schrieb:
Would you recommend a complete drawer slide replacement, or are these third-party dampers comparable in terms of durability and function?From a technical perspective, replacing the drawer slides on older Metod drawers is the more sustainable solution. This way, you retain the original integrated soft-close feature, and the functionality is guaranteed by IKEA. Third-party dampers are usually aftermarket additions that do work but may wear out faster depending on the model or fail during installation.
Regarding effort: the replacement requires removing and reinstalling the drawers, including taking out the old slides, but it can be done with standard tools. If you value longevity and a perfect fit, I recommend replacing the slides. However, for a simple retrofit without removing the drawers, third-party dampers are a viable alternative.
In addition to replacing the rails, here are some tips:
- Use only original IKEA soft-close rails, as they are perfectly matched to Metod.
- When removing the old rails, avoid loosening the mounting screws too much to prevent damaging holes in the cabinet carcass.
- The new rails often feature a click system, which simplifies installation.
- After installation, check the alignment of the drawers to ensure there is no friction.
Common mistakes when retrofitting:
- Installing the rails out of alignment
- Installing the dampers upside down
If you keep these points in mind, you will achieve a very durable solution with comfortable operation.
In summary:
- For Metod drawers with older rails, replacing the rails with the IKEA soft-close model can be the best and most reliable long-term solution.
- Retrofit dampers from third-party suppliers are possible but often not optimal in terms of durability or performance.
- Although the rail replacement requires some tools, it is straightforward and preserves the original functionality.
I recommend thoroughly checking the compatibility of your current rails before making a decision and then considering how much effort you want to invest. From a technical perspective, a complete rail replacement is the only option for optimal soft-close functionality with Metod.
