ᐅ How can I retrofit IKEA Metod drawers with soft-close mechanisms?
Created on: 3 Apr 2024 08:37
Mate1Hello everyone, I am looking for a way to retrofit soft-close functionality to my already installed IKEA Metod kitchen drawers. So far, the drawers don’t have any dampers, so they often close with a bit of force. Is there a product from IKEA or a compatible third-party solution that allows me to easily upgrade these drawers with a working soft-close feature without having to replace the entire drawer slide system? I have heard about a type of retrofittable damper module, but I’m not sure how exactly it works and if it is normally possible with Metod. I would really appreciate tips or even detailed instructions, especially if it’s possible to avoid using tools or drilling. Thank you in advance!
Hello Mate1, your question is very well formulated and shows that you have already looked into the topic. There are several options for retrofitting self-closing or soft-close features on IKEA Metod drawers, depending on which rails and drawers you have installed. IKEA itself offers a "soft-close module" for Metod that can be added later to the side rails – this is called a "soft-close adapter" and simply clicks into the existing rail.
For example, if you have Metod drawers with the blue or gray side rails, the closing function can be added using these adapters. Installation usually does not require drilling, as they either snap in place or are mounted with small screws.
If the rails are very old or not compatible, there are also damping systems from third-party manufacturers that can be attached to the drawer or the cabinet carcass. These work in a similar way but can sometimes be a bit tricky to adjust.
It is important that you carefully check which rails you currently have before purchasing – there are small differences within the Metod system that affect the suitable soft-close adapter. If you want, I can also provide you with a step-by-step explanation of how to install the soft-close module on IKEA Metod.
Here is a brief guide on how to correctly install the soft-close retrofit kit on IKEA Metod drawers:
- Step 1: Fully pull out the drawer and remove it if necessary.
- Step 2: Check whether the Metod side rails have the cutout or mounting points for the soft-close adapter – these are often identifiable by a small opening above the rail.
- Step 3: Simply snap the soft-close adapter (available from IKEA) into this opening. If screws are required, carefully fasten them with a screwdriver.
- Step 4: Reinstall the drawer and open and close it several times to test the function and allow the damper to break in.
Common mistakes:
- Installing the adapter upside down (the damper has only one correct installation direction).
- Mounting the adapter on incompatible rails.
The retrofit usually takes only a short time, no drilling into the cabinet back panel is necessary, and the result is a smooth self-closing mechanism with cushioning. If your rails do not support a soft-close module, a complete rail replacement may be needed.
Common mistakes:
uslis47 schrieb:
If the slides are very old or incompatible, there are also third-party soft-close systems that can be attached to the drawer or the cabinet. They work similarly but can sometimes be a bit tricky to adjust.Thanks for the tip, that’s exactly my problem: the slides are already 6 years old and I feel that IKEA didn’t offer the soft-close module for these back then. Would you recommend replacing the entire slide system, or are these third-party dampers comparable in terms of durability and function? It’s important to me that the solution doesn’t make installation too complicated. I have the tools, but I want to avoid unnecessary effort or damage to the cabinet.
