ᐅ How can I retrofit IKEA Metod drawers with soft-close runners?
Created on: 25 Sep 2015 18:37
Teone42
Teone42
25 Sep 2015 18:37
I have installed some IKEA Metod drawers in my kitchen, but they do not have soft-close or quiet runners. This often causes loud noises when opening and closing, which becomes annoying over time. My question is: How can I upgrade these existing Metod drawers with quiet, soft-close runners in a practical way and with minimal effort? Are there compatible rails or systems that can be easily swapped out? Which manufacturers or models would you recommend? Are there any special tools or tips I should be aware of? It is also important to me that stability and functionality are maintained and that the appearance does not suffer. I am looking forward to specific advice, preferably with step-by-step instructions.
lubla
25 Sep 2015 18:55
You can replace the old guides with BLUMOTION or soft-close runners from Blum. Simply remove the old ones and install the new runners in the same position. This usually fits well with Metod. A screwdriver is sufficient as a tool.
Noahlu
25 Sep 2015 19:23
Retrofitting soft-close slides on IKEA Metod drawers is generally doable but requires some precision. You should first check the exact drawer type and the slides currently installed: often these are standard slides without a soft-close function, usually secured with 35 mm (1.4 inches) mounting holes.
Here is my suggested procedure in steps:
- Completely remove the drawer and unscrew the slides from both the cabinet side and the drawer.
- Verify whether the existing hole heights and spacing match those of soft-close slides like Blumotion or Hettich versions. IKEA often uses standardized dimensions but not always exactly the same.
- If they are identical, for example, use Blum Tandembox cabinet rails and Blumotion dampers. You can screw them in at the same positions.
- When reinstalling, make sure the damping mechanism functions properly and the slides are correctly engaged.
- If you have the skill, you can replace the mechanism alone; otherwise, replace the entire slide.
You will need a screwdriver and possibly a drill with a small bit for additional holes. A friend with some DIY experience can help avoid misaligned or sticking slides.
If you want, I can also provide material lists or sources.
keoju
25 Sep 2015 20:07
Alternatively, IKEA offers soft-close Metod drawer slides. You can usually order these directly as replacements, and they are compatible. Installation is the same as with the standard slides.
Johnathon
26 Sep 2015 07:42
Regarding your question about how to retrofit IKEA Metod drawers with soft-close runners: the best solution is to fully upgrade to a soft-close system. This usually involves replacing the entire side runner assembly.
From a technical perspective, soft-close runners include built-in damping elements, often with hydraulic or viscous braking mechanisms. These must fit precisely mechanically; otherwise, the drawer may jam or stick.
Key points to consider:
- Hole pattern compatibility: Metod typically uses a 37mm (1.5 inch) spacing, so you should check this against the new runners.
- Load capacity of the runners: Make sure the runner can support the weight of the loaded drawer.
- Manufacturer’s installation instructions: for systems like Blumotion, the installation angle is especially important.
Additionally, I recommend:
- Removing the drawer completely
- Temporarily fitting the new runners individually to test
- Testing several times before fully tightening the screws
Tools needed: Phillips screwdriver, possibly a drill for adjustments, and a square for precise alignment.
One downside is that you will need to purchase new runners – but it’s worth it, as the comfort improvement is significant and the mechanism’s lifespan increases.
If needed, I can also recommend suitable models and sourcing options.
lubla
26 Sep 2015 09:12
Johnathon schrieb:
You need to buy new guides for it – but it’s worth it
Exactly. Replacement guides are inexpensive, and installation is quick and easy.
