ᐅ How can I retrofit soft-close hinges to Ikea Metod cabinet doors?
Created on: 1 Mar 2022 08:17
HUNORFE
Good morning everyone, I have a question and hope to benefit from your experiences and tips:
I own an Ikea Metod kitchen front without a soft-close feature, but I would like to add it afterward. Specifically, I’m referring to the Metod doors, which currently use standard hinges without damping.
My question is: How can I install a soft-close function on these existing doors without replacing the entire doors or hinges?
Are there special soft-close retrofit kits that are easy to install and compatible with the existing Metod hinges? Should I pay attention to a specific screw or drilling position to attach the soft-close components?
I want to keep the effort for the upgrade as low as possible, but of course, the result should be durable and reliable.
I would be very grateful for any advice, tips on parts, or personal experiences!
Layla
4 Mar 2022 06:50
A brief experience report: At first, I found it more complicated than expected, mainly because of the alignment. That’s why I initially installed the doors loosely, then closed them as a test before tightening the screws securely.
Removing the doors beforehand helps prevent scratches on the cabinet – so that’s definitely the right approach.
RonJarrett
4 Mar 2022 08:05
Layla schrieb:
I found it more complicated at first than I expected, especially because of the alignment.
I can confirm that. Precise measuring and adjustment are essential; otherwise, the soft-close function will be affected.
I recommend installing with fine-thread screws, as they allow for better individual adjustments.
Z
zartra
4 Mar 2022 10:20
One more tip: If the existing hinges are older and not compatible, it’s worth replacing them entirely with soft-close models.
This takes more time and costs a bit more, but is often the best solution for lasting comfort.
GIPAPO
5 Mar 2022 07:15
I have never had any issues with misalignment when retrofitting with the original soft-close dampers.
It is important that the doors are properly aligned and the dampers are screwed in precisely. Otherwise, they will get stuck.
