ᐅ How can I retrofit IKEA Metod cabinet doors with soft-close hinges myself?
Created on: 16 Oct 2015 19:37
lariru
lariru
16 Oct 2015 19:37
I am planning to retrofit soft-close functionality to the doors of my existing IKEA Metod kitchen installation. The hinges are currently the standard type without damping. I have done some research but can’t find clear instructions on how to integrate this soft-close function compatibly by myself, without completely replacing all the hinges or damaging the fronts.
An important question for me is whether there are special soft-close adapters for the Metod doors that can simply be attached to the existing hinges, or if a full hinge replacement is necessary. If there are kits or individual damping modules available, I would appreciate tips on which parts fit precisely, what to pay attention to during installation (drilling pattern, alignment, adjustable elements), and whether the effort is worthwhile for DIYers.
I am also interested in whether the retrofit might affect the door position or the operation of the hinges—meaning if later adjustments are needed to properly align the doors.
Could anyone share their experience with retrofitting soft-close on IKEA Metod doors, ideally with a step-by-step tip on the required tools and things not to forget?
Thanks in advance!
Parbo
17 Oct 2015 08:12
lariru schrieb:
An important question for me is whether there are special soft-close adapters for Metod doors that can simply be attached to the existing hinges, or if a complete replacement of the hinges is necessary.
This is a key point. Basically, there are two ways to retrofit soft-close on Metod doors:
- Replace the entire hinges with soft-close models that IKEA itself offers. These are specifically designed for the Metod system and provide optimal closing comfort. For this, the old hinges must be fully removed and the new ones installed.
- Retrofit soft-close modules available from third-party or some accessory manufacturers. These are small dampers that are mounted onto the existing hinge or the cabinet carcass. However, compatibility is crucial here: the drilling pattern on Metod is standardized, but many of these dampers may attach in different positions and might require additional drilling.
lariru schrieb:
whether the effort is worth it for DIY enthusiasts.
From my experience, the effort is greater when doing a full hinge replacement, but it is more reliable because you get a well-engineered and tested soft-close solution that continues to function properly even after years. Installing individual dampers can be cheaper and faster but may lead to issues with closing force and positioning.
For alignment: after installing the soft-close hinges, you’ll need to adjust the doors again. The Metod hinges have adjustment screws on multiple axes. It’s recommended to mount the doors loosely at first, then align them, and finally tighten everything.
Tools you’ll need:
- Cordless drill or screwdriver
- Possibly a small drill if new holes are necessary
- Spirit level or a small plumb line
Do you already have information about which type of hinges you currently have? That would help assess things more precisely.
dota57
17 Oct 2015 11:03
Parbo schrieb:
It is recommended to mount the doors loosely at first, then align them, and only tighten them fully at the end.
I can only agree with that. I did exactly that with my Metod kitchen some time ago.
For retrofitting soft-close, IKEA actually provides the complete hinge with integrated damping. Because of the specific drilling pattern and plastic parts, these hinges are not easily replaceable with simple add-on dampers.
If you want to replace the original hinges, make sure to use the “Metod Soft-Close 110°” model. It fits the same mounting holes perfectly and is reasonably priced.
Note during removal:
- Carefully unhang the doors; the hinges remain attached to the cabinet
- Pay attention to the hinge plate position when reinstalling
If you decide against a full replacement, there are retrofit kits available (e.g., clamp-on or clip-on dampers), but these rarely fit Metod perfectly and can affect function.
My advice: If you have some DIY skills, a complete replacement is worth it. The investment is manageable, and the result is better in the long run.
HORST41
18 Oct 2015 16:44
lariru schrieb:
I’m also curious whether the retrofit might affect the door position or the function of the hinges, meaning if adjustments would be needed later to properly align the doors.
This is exactly what I underestimated during my first retrofit. At first, I thought I could simply stick the soft-close dampers on or attach them to the existing hinges. Unfortunately, this caused the doors not to close properly and to be unevenly aligned quite often.
My recommendation: If possible, replace the hinges entirely, even if it seems more labor-intensive at first. While you’ll need some patience for fine-tuning initially, in the end you’ll have a properly functioning door with smooth damping.
Additionally, with Metod hinges, you can adjust them horizontally, vertically, and in depth—use these adjustments to compensate for any misalignment caused by the new damping.
If you’re looking for a more budget-friendly option, you could try clamp-on dampers, but keep in mind that these can sometimes reduce the lifespan of the hinges or alter the door’s positioning.
If you’re curious: I replaced all the hinges in my kitchen with soft-close versions about six months ago, and I’m very happy with the result today.
