ᐅ How can I restore Malm furniture?
Created on: 20 Feb 2017 14:23
MARTAU
MARTAU
20 Feb 2017 14:23
Some time ago, I bought several cabinets and dressers from the Malm series at Ikea, which now show some noticeable signs of wear in certain areas. Before deciding to replace the furniture completely – which would be costly – I would like to know how to effectively restore Malm furniture.
I am particularly interested in methods for removing scratches, discoloration, or small dents on the surfaces. It would also be helpful to learn how to match color tones when touching up or how to treat the surfaces properly. Which tools and materials do you recommend? Are there any specific products that work especially well for veneer or painted finishes?
Thank you in advance for your tips and experience!
Fitigu
20 Feb 2017 16:47
When restoring Malm furniture, it is especially important to correctly identify the surface type and treat it accordingly. The series is usually made of particleboard and coated with either a laminate or a paint layer. Here are some points that often help:
- Scratches on laminated surfaces can often be effectively repaired using special furniture touch-up pens or wax crayons that match the color of the surface.
- For painted surfaces, fine sandpaper (grit 240 to 400) is recommended to gently sand the damaged area, followed by repainting with a matching color.
- Dents or deeper damage often require applying wood filler or putty, which should be sanded after drying and then repainted.
- It is important to work in well-ventilated areas and to use products that are approved for the specific surface type.
For color matching, I recommend testing on small areas first, especially with paints, as the shade can vary between batches. Tools such as fine brushes, sanding blocks, and suitable stationary products are necessary. For extensive damage, consulting a professional can also be beneficial.
V
valerie-tr
21 Feb 2017 11:12
to answer your request as thoroughly as possible, I will explain each step in detail, as working with Malm furniture can be quite tricky:
1. Identify the type of damage: Malm furniture is made of coated particleboard (DFP) with a plastic film or melamine surface. This means you should not expect a solid wood finish and need to handle the surface with care.
2. Small scratches: Wax crayons or furniture repair markers are among the quickest solutions here, but it is important to pay close attention to color matching. Apply carefully with a fine cotton swab, but immediately wipe off any excess material to avoid color buildup.
3. Larger scratches and dents: Since it is a coated material, you cannot simply sand damaged areas without exposing the particleboard underneath. I recommend using polyester filler, applied thinly to level out the depressions, followed by very fine sanding (400 grit). If the surface is glossy, be sure to use a clear coat afterward that matches the original sheen.
4. Color matching: Furniture paints or touch-up sticks come in various sheens, so it is important to check both sheen and color carefully. Acrylic paint is usually recommended because it is easy to work with. Apply it very thinly to minimize differences.
5. Preparation: Before starting any work, thoroughly clean the surface—soapy water or a mild cleaning agent works well, followed by drying. For stubborn stains, there are special cleaning pastes available.
6. Tools: In addition to sandpaper and brushes, polishing compounds can help restore an even appearance after treatment.
Could you please describe the exact type of damage? For example, how deep the scratches are or if there are any stains caused by liquids? This would help provide more targeted advice.
Annedeo
21 Feb 2017 19:34
Hello MARTAU,
I especially agree with the detailed explanation from valerie-tr. With IKEA furniture like Malm, it’s important to pay close attention to the surface texture – they can be sensitive to excessive sanding or harsh cleaning agents.
Additionally, to remove surface scratches, you can use very gentle sanding sponges that won’t damage the texture but will smooth out minor imperfections.
Also, for color touch-ups, sometimes a matte clear coat is helpful to visually blend the new paint with the surrounding area.
If you have little experience, I recommend practicing on an inconspicuous spot first. This way, you can create test areas before working directly on the furniture.
I hope this helps! If you can provide more details about the affected areas, I can give you more targeted advice.
blapau
23 Feb 2017 09:17
valerie-tr schrieb:
do not simply sand off the coating material without exposing the underlying panel
This is an important point that is often underestimated. Malm is sturdy, but the thin plastic foil allows little room for sanding work.
In my experience, for minor scratches, wood care oil works well – it slightly enhances the contrast and effectively conceals small white scratches. For more severe damage, however, a combination of filler and custom paint is the better approach.
Fitigu schrieb:
Check color matching especially with test areas
I agree with that. Especially with paints, colors can change during the drying process. A paint match before treatment can save a lot of trouble.
Regeneration also includes treating the furniture after repair with a suitable care product that protects the surface and maintains an even gloss.
