Hello everyone, I am facing the challenge of optimizing the layout of my small apartment and have heard that IKEA Platsa is a very flexible modular system that adapts well to different room situations. My apartment is only about 22 sqm (237 sq ft) in total, and I am specifically looking for ideas on how to repurpose PLATSA to make it as multifunctional as possible – for example, incorporating storage, a wardrobe, possibly a room divider, or even a sleeping area. It is important to me that the furniture pieces are not just placed side by side but are cleverly connected or modified to save space. Has anyone had experience with this? How could I best customize the system to achieve multiple functions in such a small space? Are there practical tips or design approaches you would recommend?
kokifi schrieb:
I’m facing the challenge of furnishing my small apartment in the best possible way, and I’ve heard that IKEA PLATSA is a very flexible modular system that adapts well to different room layouts.You’ve recognized that very well—PLATSA is indeed highly customizable, which makes it ideal for small apartments. I would recommend experimenting especially with the different widths and heights of the modules. For example, you can use lower modules as a bench with storage underneath, and then place a cushion on top—this way you get a seating area with integrated storage.
In a step-by-step process, you might consider:
- What are your main needs (storage, seating, sleeping area)?
- What are the wall dimensions available (height, length)?
- Could you, for instance, connect modules to create a kind of room divider that is accessible from both sides?
From a technical perspective, make sure to use sturdy connectors, especially if the modules are freestanding or used as a room divider. Sometimes PLATSA’s standard fittings are sufficient, but in other cases, it makes sense to get additional corner brackets or stronger screws.
One option could be to integrate a low bed segment, about 90cm (35 inches) wide and approximately 200cm (79 inches) long, with other modules arranged vertically around it for storage. This saves space and creates a clever interface for everyday living and guests.
Have you tried combining doors with open shelves? This creates a lighter feel while still providing good organization.
Domau0 schrieb:
One option would be to integrate a low sleeping area within a segment, about 90cm (35 inches) wide and approximately 200cm (79 inches) long, with other modules used as vertical storage on top.That’s a very good tip, especially in small apartments, where multifunctional furniture can save a lot of space. I would add that it’s worth paying attention to small details like internal organization within the PLATSA modules—for example, using drawers or boxes to keep small items neatly stored.
If you want to use the modules as room dividers, make sure to consider their stability and access from both sides, as this greatly improves usability. One often overlooked option is installing hidden LED strips in the shelves. These create a pleasant ambiance without taking up any extra space.
What does your room layout look like? Are there specific corners or niches you want to use efficiently? Sometimes even small gaps behind doors or under windows can be great spots for PLATSA modules.
For small apartments, it’s practical to use PLATSA as a low cabinet with a seating surface on top. You can also stack modules to create simple storage space. If you want to include a sleeping area, choose a rectangular module and place a mattress on it. Usually, that’s all you need for multifunctional use.
klo61 schrieb:
If you want to use the modules as room dividers, be sure to pay close attention to stabilityThis is an important point. I recommend that when using them as room dividers, you ensure stability not only through fasteners but also consider the back side. Often, the backs of PLATSA units are very thin or even missing if you want to access the system from both sides.
In these cases, you can use lightweight plywood panels, cut to size and mounted on the back of the modules. This improves stability and gives the furniture a higher-quality, more solid look.
Additionally, with modular PLATSA components, you can flexibly respond to different needs by adding or leaving out doors and drawer inserts. This way, the system remains adaptable at any time.
If space is limited, I also recommend using storage up to the ceiling and planning the upper modules for safe use and easy access, possibly with flap doors or drop-down drawers.
BOMILAN schrieb:
If you want to integrate a sleeping area, use a rectangular module and place a mattress on top.This is a very pragmatic solution, but especially in small spaces, you should also consider ergonomics and safety, particularly if the modules are not specifically designed as bed constructions.
I would recommend carefully assessing the loads and load-bearing points and, if necessary, reinforcing them with additional supports. This can be done by adding cross beams inside the modules or using solid wooden boards as a base.
Also: If you want to create a sleeping area with PLATSA, consider the mattress height and type. Cold foam mattresses are lightweight and flexible, but the base needs to be flat and stable; otherwise, the mattress will deteriorate.
And one more question for you: How flexible do you want the solution to be? Should everything be fixed and permanently usable, or are you looking for a semi-mobile setup that you can reconfigure as needed?
