Hello everyone, I plan to replace the doors of my Ikea Pax wardrobe because I want to change the design. I am interested in the best way to remove the old doors and install new ones. Could someone please explain step by step what I should keep in mind? I am especially interested in whether I need to pay attention to specific screws or fasteners when taking off the doors, if the hinges can be reused, and how to properly adjust the new doors on the wardrobe frame. Thanks in advance for your tips!
As an addition: Ikea Pax doors are mostly attached with clip hinges that can be unlocked using a small screwdriver or by pressing with a finger. It is important to slightly lift the door before removing it and then release the lock on the hinges. The hinges remain on the frame, allowing for easy door replacement. When installing the new doors, it is recommended to fine-tune the alignment using the adjustment screws on the hinges to achieve optimal gaps.
BARSAN schrieb:
The hinges stay attached to the cabinet, and you can simply remove the doors.That is generally true, but it only applies if you keep exactly the same model series for the doors. Otherwise, I strongly recommend checking the hinges on the cabinet frame to ensure they are compatible with the new doors. Otherwise, you may encounter issues with stability or misalignment. Ikea Pax is not entirely standardized when it comes to doors and hinges.
I recently replaced the Pax doors myself – it felt almost like a small DIY project. Tip: Check in advance whether your new doors have the hinges positioned on the side or in the middle, as this makes a big difference for the fit. When adjusting, take your time; a well-aligned cabinet is more enjoyable in the long run. By the way, if the door gets stuck, small turns of the screws on the hinges often help. Good luck, it will definitely turn out great!
