ᐅ How can I repair Malm furniture?
Created on: 17 Sep 2024 13:07
ron_edi
ron_edi
17 Sep 2024 13:07
Hello everyone, I have some IKEA Malm furniture pieces that have developed minor damage over time, such as scratches, chipped edges, and slightly loose drawers. Since I prefer to repair the furniture myself before buying replacements, I would like to know: What methods and materials work best for targeted and long-lasting repairs on Malm furniture? I’m especially interested in tips for fixing scratches on veneered wood, reattaching loose parts, and possibly refinishing the surfaces to maintain the original appearance. Are there specific repair kits or tools that are particularly effective, or do simple household remedies prove reliable? Thanks for your advice!
Lorukeo
17 Sep 2024 14:03
For repairing IKEA Malm furniture, it is important to first carefully assess the damage. For scratches on veneered surfaces, I recommend using special repair wax sticks or wood repair kits matched to the specific wood color. These fill small scratches and blend in well visually. For chipped edges, use a high-quality wood glue to gently press the veneer layer back into place and leave it to dry under some weight.
For loose drawers, check that screws and connectors are secure and tighten them if necessary with the appropriate Phillips or Allen key. If the screws are loose in the wood, filling the holes with wood filler before reinserting the screws helps.
After gluing, applying a surface oil or a suitable furniture care pen for laminate is recommended to restore a uniform appearance.
Tools: Furniture repair kits (available from hardware stores) typically include touch-up pens, waxes, and putty and are usually sufficient. Optionally, very fine-grit sandpaper (400+) can be used for light finishing.
gregto
17 Sep 2024 16:47
First of all: Good luck with your project! 🙂
I would add that Malm furniture is often assembled using particleboard with veneer, which makes repairs a bit more challenging compared to solid wood. Especially with chipped corners or larger cracks, you need to be careful, as the material can break or come apart.
Regarding scratch repair: If you don’t have repair wax on hand, a suitable wax crayon or wood touch-up marker from a hardware store will also work. It is important to thoroughly clean the surface beforehand (remove dust and grease), and for deeper scratches, you can gently use fine sandpaper – but only very lightly.
For loose drawers, it often helps to check the drawer slides. Sometimes not only screws are loose, but dirt or dust can block smooth movement. The screws often require a Torx or hex key – not all are Phillips.
Lorukeo schrieb:
Bei abgeplatzten Kanten ist ein Holzleim auf guter Holzleimqualität (Photovoltaikanlage-Leim) zu verwenden
Absolutely correct! Just be careful not to apply the glue too thickly, or you will end up with stains later on.
If you are looking for more specific repair kits, I can recommend “Liquid Wood” by Hermoplast. It’s quite good for rougher areas.
One more tip: Always test the repair product first in an inconspicuous area to check if the color matches.
Domau0
18 Sep 2024 09:18
A more detailed approach to repairing your Malm furniture:
First, you should examine the damage, especially the structure beneath the surface. Malm often uses medium-density fiberboard (MDF) with a foil coating or veneered surfaces, which limits repair options. Therefore, a gentle approach is important.
For repairing veneer chips:
Step 1: Clean the area from dust and any old adhesive residues using a mild cleaner; avoid solvents at all costs.
Step 2: Apply clear wood glue paste or special contact adhesive with a small brush, supporting the lifted veneer edge and pressing it down carefully.
Step 3: Secure with small clamps or weights to ensure the area dries flush and without air bubbles.
For scratches, there are different options:
- Lightly polish with furniture polish or a touch-up marker
- For deeper gouges, fill with wax filler, then smooth with very fine sandpaper (grit 600-800) and finish with furniture polish to match the gloss of the surrounding area.
When tightening screws or inserting connectors, be cautious: repeatedly unscrewing can cause the threads in the MDF to strip. I recommend using special wood thread inserts (metal inserts) or filling the hole with wood filler before reinserting screws to improve stability.
Finally, you can protect and visually even out the surface with a suitable protective varnish or clear furniture wax.
gregto schrieb:
Das "Liquid Wood" von Hermoplast empfehlen
That’s a good option, yes, but you should check beforehand whether the surface remains compatible with furniture polish after application.
If you have specific spots or further damage, feel free to describe them in more detail. Sometimes a single method isn’t enough, and a combination of techniques is advisable.
juMira46
19 Sep 2024 08:42
Hey, I’d like to jump in with a practical tip that I used myself on my Malm desk. 🙂
The surfaces of Malm furniture are often covered with a foil or veneer, which can peel off easily at the edges or develop small scratches. I had exactly this problem with the drawer sides – a bit chipped. Instead of going for major repairs, I got a furniture touch-up pen in a wood tone and carefully colored in the chipped areas. It looks really neat afterwards, almost like new! Then just gently polish with a soft cloth, and that’s it.
Domau0 schrieb:
Mehrmaliges Ausdrehen kann zum Ausbrechen der Gewinde im MDF führen
I can confirm this – so it’s better to tighten all parts properly only once and otherwise be careful.
If you feel like it, you could also try applying a thin coat of clear varnish – this makes the surface more resistant to new scratches. Hardware stores usually offer glossy or matte options, depending on your preference.
Good luck, and fingers crossed your Malm furniture looks great again soon! 😉
BARSAN
21 Sep 2024 11:59
Pack wood glue for veneered areas and wood filler for holes.
Use color-matched repair wax sticks to fill scratches.
Tighten screws if they become loose, and apply wood filler to loose threads beforehand.
For the final touch, furniture polish is suitable; it protects and refreshes the appearance.
