ᐅ How can I repair Malm furniture without professional knowledge?
Created on: 8 Apr 2024 18:12
anjome45
I have a Malm bed and a Malm wardrobe from Ikea at home, both of which have unfortunately suffered some wear and tear due to moving and rental activities. Since I am neither a carpenter nor very experienced with DIY, I want to try repairing the furniture as independently as possible. I’m mainly interested in methods and materials that allow for fairly neat repairs to stability and appearance, even without extensive technical knowledge.
Specifically: How can I secure loose screws, touch up small dents in the wood or the finish, and possibly fix squeaky mechanisms? Are there simple tools or aids that I should definitely have?
I look forward to tips, tricks, and an idea of the effort and time involved. Thanks in advance!
Lucien
10 Apr 2024 10:02
A structured approach is extremely helpful.
1. Categorize damage: structural vs. cosmetic.
2. For structural issues, first repair screw holes (using toothpicks/glue or dowels).
3. Treat cosmetic damage with suitable repair kits—depending on the material (melamine coating vs. veneered wood).
4. Check function (drawers, doors) and apply lubricant to clean surfaces.
Minimal tool list: cordless drill, wood glue, hex key set, small hammer, fine sandpaper, repair wax kit, silicone spray.
This keeps the effort manageable and prevents frustration.
anjome45
10 Apr 2024 15:27
Thank you to everyone who has replied so far – I now have a good idea and will spend the next few days working on a small affected cabinet.
One last question: How important is it to slightly disassemble or remove the furniture at the damaged areas beforehand? Or can screws usually be repaired while the unit remains assembled, without loosening the entire structure?
Thanks for sharing your experience!
kulau
10 Apr 2024 16:05
anjome45 schrieb:
How important is it to partially disassemble the furniture at the damaged spots before starting repairs?
Ideally, yes, because with removed parts you can work more precisely and access holes or edges better from all sides. This also helps prevent damage to other furniture components from tools or adhesive.
If disassembly is very complex, repairing the furniture while it is still assembled is possible, but this can affect the quality—such as less secure joints, less neat application of glue, and potential stress on the material.
My advice: If possible, at least remove the problematic parts—such as drawers or doors. This is usually straightforward and well worth the effort.
