ᐅ How can I repair Malm furniture without professional knowledge?
Created on: 8 Apr 2024 18:12
anjome45
I have a Malm bed and a Malm wardrobe from Ikea at home, both of which have unfortunately suffered some wear and tear due to moving and rental activities. Since I am neither a carpenter nor very experienced with DIY, I want to try repairing the furniture as independently as possible. I’m mainly interested in methods and materials that allow for fairly neat repairs to stability and appearance, even without extensive technical knowledge.
Specifically: How can I secure loose screws, touch up small dents in the wood or the finish, and possibly fix squeaky mechanisms? Are there simple tools or aids that I should definitely have?
I look forward to tips, tricks, and an idea of the effort and time involved. Thanks in advance!
For squeaky drawer slides: silicone spray usually does the trick. Just spray it on and slide the drawer back and forth a few times.
If screws come loose, fill the hole with a toothpick and wood glue, let it dry, then carefully retighten the screw.
For dents: wax repair kits from a hardware store are quick and easy to use.
Hey anjome45,
I love the challenge of restoring furniture, even without professional skills—just like you! 🙂
A little tip for the wood glue and toothpick trick: it feels a bit strange at first to push a piece of wood into the hole, but it really works well. Just use a screwdriver to help position everything, then make yourself a coffee while it dries.
As for the blemishes: wax repairs are almost like a paint palette, with colors that let you precisely fill in spots or conceal small scratches. It really makes a difference and looks quite good!
What I often do: finish by wiping everything down with a soft cloth—it looks really neat and brings out the best.
Good luck—I'm sure you’ll manage it! 😉
Regarding the surface and visual details: Repair kits for plastic surfaces and furniture are very advanced nowadays. They usually include wax, filler, and color pencils for touch-ups.
It should be noted that Malm furniture typically has a melamine-coated surface, which makes painting more difficult. Fine scratches can often only be diminished with special polishing pastes designed for melamine.
A complete repainting should be avoided without professional knowledge – otherwise, the difference might be more noticeable than the damage itself.
Wood repair waxes can be found in hardware stores, with color ranges matching common Ikea shades.
anjome45 schrieb:
How exactly should I insert the wood piece? Does it need to be very fine?The finer, the better. Small toothpick tips or thin wooden sticks work well. Don’t buy anything too thick, ideally around 2–3 mm (about 0.08–0.12 inches) in diameter.
anjome45 schrieb:
How long does the drying time need to be at minimum?Let it dry for at least 1–2 hours, but 4–6 hours is better before you screw again. Faster doesn’t mean better.
In any case, keep two things in mind: don’t screw too deep to avoid splitting the material, and for larger repairs it’s better to apply a second layer of wood glue and wait again.
Important: Check that your screwdriver has enough torque to tighten the screw firmly without damaging the repaired wood again.
One more note: Make sure to test the load after the repair to see if the furniture remains stable.
If drawers or doors no longer close properly or feel loose, also check the fittings and connectors for wear or deformation.
Simply tightening the screws is often not enough. In some cases, slightly enlarging the screw holes and then restoring the fit with plastic inserts (available in furniture fitting kits) can help.
Keep in mind that Ikea furniture is primarily designed for flat-pack delivery and easy assembly. Therefore, repairs should ideally avoid any modifications to the basic structure.
One more tip: Don’t overestimate the stability of filled holes. Especially with heavily damaged drilled holes, it’s best to consider the repair only as a temporary solution.
If the damage is significant, it’s better to plan for a replacement or a new purchase. This saves time and effort.
Also: Use wood glue sparingly and immediately wipe off any excess with a damp cloth, as this greatly facilitates the subsequent surface treatment.
