ᐅ How can I repair Malm furniture myself?
Created on: 12 Jan 2023 14:37
maangel
maangel
12 Jan 2023 14:37
I have several Malm furniture pieces, mainly dressers and nightstands, that have minor damage like scratches, chipped edges, or loose drawers. I’m interested in how to best repair these issues myself without having to completely disassemble the furniture or use specialized tools. Are there recommended methods or materials for restoring the surface or fixing the drawer mechanisms? Tips on care after the repair would also be helpful to prevent further damage. Does anyone have experience with what works well for Malm furniture, which usually consists of coated particleboard?
nonlau35
12 Jan 2023 15:02
For scratches on coated surfaces, wood filler or a furniture repair kit works well. Small edges can be filled with transparent wood glue repair adhesive. For drawers that stick, simply clean the rails of grease and apply a light coat of oil. This can be done quite easily without special tools.
Fitigu
13 Jan 2023 10:49
For repairing chipboard furniture, a precise assessment of the damage is recommended first, as the material (particleboard with melamine resin coating) is not very tolerant to moisture or harsh mechanical impact.
For scratches and chipped areas, repair-ready furniture wax or a water-based touch-up pen is often used, which blends well with the color and texture. It is important to clean and degrease the surface beforehand.
For damaged edges, special edge banding made of plastic or veneer can be cut to size and applied using an iron or contact adhesive. Loose drawers often have issues with the slides; in these cases, screws should be tightened and the rollers or tracks lubricated with silicone spray.
Care after repair: Furniture should be regularly wiped with a mild, lint-free cloth to avoid abrasion. Avoid aggressive cleaning agents, as they can damage the coating.
None of this requires specialized heavy tools, but it does require some care and suitable materials from the hardware store.
blapau
14 Jan 2023 08:23
Fitigu schrieb:
For damaged edges, you can cut special edge banding made of plastic or veneer yourself and apply it using an iron or contact adhesive.
This is a key point I want to add. Especially with Malm furniture, the edges are often the weak spots, and many underestimate how strong and durable a properly applied edge banding can be.
It is also important to pay attention to the correct temperatures when ironing – too hot can damage the coating, too cold won’t allow the adhesive to bond properly. Furthermore, lightly roughening the repair area before application is recommended to improve adhesion.
maangel schrieb:
Are there recommended methods or materials to restore specifically the surface or the mechanism of the drawers?
For the mechanism: Often, a good lubricant based on silicone or PTFE that does not attract dust helps. I would avoid oil-based products like WD-40, as they do not work well with wood surfaces and can cause dirt buildup later.
Finally, a tip: Performing repairs in well-ventilated rooms and allowing materials to acclimate for 24 hours before use will lead to better results.
