ᐅ How can I repair an IKEA BRIMNES drawer that is no longer working?
Created on: 22 Dec 2024 09:43
TeleonasGood morning everyone, I have a problem with an IKEA Brimnes drawer that no longer works properly. Specifically, it can no longer be fully opened, and when placing items inside, it often gets stuck or jams. The drawer track itself is still intact, but I suspect that either the guide rails are bent or there is an issue with the internal sliding mechanism. I don’t want to simply replace the part, as that would be expensive and inconvenient. Has anyone had experience repairing these particular drawers? How can I specifically proceed to identify the cause and get the drawer fully functional again? Any step-by-step instructions or troubleshooting tips would be greatly appreciated, especially regarding the correct alignment or checking of the rails.
Hello Teleonas,
First of all, your issue is a fairly common case with furniture like the IKEA BRIMNES drawer, which is often prone to reduced smoothness due to its economical construction. To give you a step-by-step guide on how to proceed, we need to go through some technical details.
- First, you should completely remove the drawer from the carcass. This usually works by pulling the drawer out fully and then pressing or lifting the side locks on the rails—depending on the system installed.
- Check the metal or plastic rails for any deformation, dirt, or loose screws. Even small crumbs or dust buildup can significantly affect smooth movement.
- Inspect the drawer sides for cracks or broken fasteners that could obstruct the sliding action.
- If the rails are bent, you can carefully reshape them with pliers or a screwdriver—but this requires a delicate touch to avoid breaking them.
- Important: The rail must be installed parallel to the furniture carcass. It helps to use a spirit level or ruler to check the alignment.
- A silicone-based lubricant applied to the sliding points can also help, as it is non-sticky and does not attract dust particles.
- If your rail is broken or severely damaged, you can order replacement rails from IKEA support, which can be easily exchanged.
- A final check of the sliding direction and resistance when closing and opening completes the process.
Can you tell me exactly which parts are not moving or are sticking? Are there any sounds when moving? That would help narrow down the problem further.
Palenar schrieb:
First, you should fully remove the drawer from the cabinet.Why is there always this assumption that the entire piece of furniture has to be completely disassembled? Sometimes the repair is best done without removing it. I suspect that some users simply don’t have the time or patience to take everything apart.
Palenar schrieb:
A silicone-based lubricant on the sliding points can also help, as it isn’t sticky and doesn’t attract dust particles.However, I agree: lubricants are often underestimated, but be careful with household oils—they just attract dirt and make the problem worse.
A provocative thought from me:
- Isn’t an IKEA drawer like this generally too weakly constructed to function well over the long term?
- Maybe repairing it is a lost cause, and it would be smarter to simply replace the part?
Of course, that’s not always the right answer for everyone, but sometimes a small change in perspective can help.
I would like to add a structured quick guide here on how to proceed if the BRIMNES drawer is not functioning properly:
1. Remove the drawer:
- Pull it out fully, then press the locks (usually small levers on the side rails),
- Then gently pull the drawer completely out of the cabinet.
2. Inspect the runners:
- Are the runners clean, straight, and free of damage?
- Is there any rust or dirt that could be obstructing smooth movement?
3. Adjust:
- Carefully loosen the screws that attach the runners to the furniture.
- Realign the runner with a small gap and retighten the screws.
4. Lubrication:
- Apply lubricant to the sliding surfaces using a brush or spray (silicone spray is ideal).
- Avoid using oil-based products!
5. Reinstall and test:
- Reinsert the drawer and open and close it several times.
- Check if catching or sticking still occurs.
If the drawer still sticks, the problem might be due to the drawer bottom or back panel bending under load – in this case, consider slight corrections or replacement of individual parts.
I recommend paying close attention to the alignment of the runners, as even a few millimeters difference in parallelism can significantly affect the sliding performance.
If you want, I can also share a tip on how to make the drawer operate as quietly as possible again.
3. Adjust:
4. Lubrication:
