ᐅ How can I repaint IKEA Hemnes furniture in a DIY project?
Created on: 29 May 2024 10:13
billgu
billgu
29 May 2024 10:13
Hello everyone, I am planning to repaint an IKEA Hemnes piece of furniture as part of a DIY project to give it a completely customized look. Since the Hemnes series is mostly made of solid pine wood with a thin lacquer coating, I would like to clarify a few specific questions before I start: What preparations are necessary to properly remove or treat the old lacquer? What type of paint is best suited to ensure the surface remains durable and resistant? Are there any special tips for the finish, such as matte or glossy options, to guarantee a good appearance and longevity? I am very much looking forward to your experiences and advice to avoid common pitfalls.
Ankeli
29 May 2024 11:27
First, lightly sand the old paint to help the new paint adhere better. It is best to use chalk paint or acrylic paint designed for furniture, as these are durable and dry quickly. The finish depends on the desired look; a matte finish often appears more refined.
Lorukeo
29 May 2024 12:56
Regarding surface preparation: Hemnes furniture is made of solid wood but often coated with clear lacquer. Therefore, sanding with 120-220 grit sandpaper is essential to roughen the surface and prepare it for the new paint. It is best to use a primer specifically designed for wood to prevent rust or paint peeling. For the finish, acrylic paints or chalk paints are recommended, as they are resistant to scratches and moisture. Avoid oil-based paints, as they seal the wood and make future touch-ups more difficult.
warrenka57
29 May 2024 14:15
I can fully understand wanting to avoid mistakes with a piece of furniture like Hemnes. It has happened to me as well that I didn’t sand thoroughly enough, and the paint peeled off after a few months. I also think it’s important to take your time and be patient before painting—especially during drying! I’m keeping my fingers crossed that the result turns out perfect and brings a lot of joy!
billgu
30 May 2024 09:04
Thank you, that’s a helpful tip, especially since I was wondering how important this primer really is. Does the primer need to be completely dry before applying the paint layer? And how many coats do you recommend for this piece of furniture to achieve a smooth and durable finish? Also, I’m wondering whether it’s better to remove the handles from Hemnes or if it’s okay to paint over them.
Ankeli
30 May 2024 11:42
Primer must be completely dry, which usually takes 2-4 hours. Two coats of paint are generally sufficient, allowing thorough drying between coats. Remove handles to ensure a clean finish and to avoid missing any spots.
