ᐅ How can I remove old vinyl wallpaper?
Created on: 2 Oct 2012 17:03
Gitta56-1
2 Oct 2012 17:03
I am currently trying to update our house and am removing the old wallpaper in the hallway. It has a kind of plastic foam coating on the surface, which makes it very difficult to remove with water. I have to go over it with a sponge for a long time to reach the base layer. Overall, using a scraper to remove it is just as time-consuming. Does anyone have any tips on how to remove this stubborn wallpaper as quickly as possible?
MODERATOR
2 Oct 2012 21:08
You will need a so-called wallpaper perforator, which is a roller covered with spikes. Use it carefully—just enough to punch holes through the wallpaper, but not the plaster underneath.
Then spray the wallpapered area with wallpaper remover or a solution of warm water and dish soap (cheaper and works just as well).
Wait a bit, then start removing the wallpaper. If it doesn’t come off right away, repeat the process; it’s important that the textured wallpaper is thoroughly perforated. Only then can the wallpaper remover reach the adhesive.
Richard-1
4 Sep 2014 13:11
I also had this problem some time ago. This type of wallpaper is extremely stubborn and caused me quite a bit of frustration. I also got one of those spiked rollers, and after practicing several times, it worked well.
Serena1990-1
12 Sep 2014 13:47
Removing a plastic wallpaper is quite a task. It can't be done easily with just regular dish soap. Then my friend came along with a wallpaper spiked roller, and lo and behold, that finally worked.
bastian-1
4 Dec 2014 15:00
This is exactly where patience is required. Simply soak it several times and refresh the dishwashing detergent. Then this vinyl wallpaper will almost come off the wall by itself.
Renif-1
11 Dec 2014 08:15
I had the same problem some time ago. I managed to fix it using a wallpaper scorer.
Have fun!
