ᐅ How can I remove and clean Malm drawers?
Created on: 8 Nov 2022 07:34
KUJULIUS
I have several Malm dressers from IKEA at home and wanted to fully remove the drawers to clean them thoroughly. Since the drawers sometimes fit very tightly or are a bit tricky to pull out, I’m wondering if there is a proper method to remove these drawers without causing any damage, and what to pay attention to when cleaning the runners and the inside of the drawers.
Are there any special tricks or tools that work particularly well? I especially want to clear the runners of dust and dirt. I am also considering whether to oil them, but I have heard that this can sometimes be harmful.
I hope you have experience or good tips on how to professionally remove and safely clean my Malm drawers so they run smoothly again.
Thanks in advance!
Keatondra
9 Nov 2022 12:06
KUJULIUS schrieb:
I’m curious whether damage can occur if you’re not careful—for example, breaking the clips or bending the rails.
Yes, the plastic clips are delicate.
A bit of pressure is normal, but if you pull too abruptly or unevenly, the clips can break or become deformed. This will cause the drawer to slide worse or prevent it from being reinstalled.
When removing the rails themselves, keep in mind that they are usually attached with screws, which can be removed with a standard Phillips screwdriver. The rails are sturdy, so no need to worry.
Whether it’s worth replacing the rails depends on their condition. Replacement parts from IKEA are relatively inexpensive; for very stuck or damaged drawer slides, replacing them can significantly extend the life of the dresser.
If you want, I can send you a short guide on how to remove and replace the rails.
