ᐅ How can I effectively protect BILLY shelves in areas with high humidity?
Created on: 3 Oct 2023 08:12
di-elaine5
I am looking for reliable and practical methods to protect IKEA Billy shelves from high humidity. Specifically, I have an apartment with a relatively constant humidity level of 65% to sometimes 75%, where the shelves have already started showing slight swelling and deformation.
I want to prevent permanent damage to the shelves, especially since I use them for books and decorative items. What measures are recommended to protect the wood from moisture? Are there special sealants, coatings, or other protective treatments that have proven effective for Billy shelves due to their MDF or particleboard construction?
I would appreciate any advice on prevention, suitable products, or alternative placement options!
GOLO42
3 Oct 2023 11:57
Regarding your concern, di-elaine5:
It is definitely possible to combine transparency and effectiveness. A high-quality polyurethane clear coat provides a very durable, water-repellent protective layer that remains almost invisible.
When applying, always work in well-ventilated areas and coat the edges first, as they absorb moisture earlier and more intensely. Treat the corners and edges with a brush, then use a high-quality foam roller for the larger surfaces to achieve a smooth finish.
Even better is to ensure the surface is clean and matte before painting (light sanding with 220-grit sandpaper), so the coating adheres well and the protective effect is maximized.
If minimal visual impact is essential, wax stains can also be considered. However, these offer less strong protection against high moisture and require regular reapplication.
Regarding the technique: apply several thin layers (at least 3), since thick layers often crack or dry unevenly.
For already starting deformations, it is important to note that moisture may not only be on the surface but have penetrated the material. In that case, replacement should be considered, along with improved air dehumidification and more suitable storage conditions.
BOMILAN
3 Oct 2023 12:15
Clear varnish or a thin polyurethane coating is truly the best solution for moisture problems. Don’t forget the edges, otherwise moisture will seep in there.
Also, always ensure good air circulation – avoid placing shelves directly against the wall.
retau
4 Oct 2023 07:53
Wow, this topic is really interesting! 🙂 I also had to protect my BILLY shelves because my basement apartment was always a bit damp.
What worked really well for me: after sanding, I applied a special wood protective oil (linseed oil based) – it soaks in well and stays transparent! Then I added two coats of clear varnish inside and out. This way, the shelves are now sturdy and look great.
The most important thing is good preparation and patience during drying.
Good luck to you all! 😉
LUISABEL
4 Oct 2023 09:27
retau schrieb:
After sanding, I applied a special wood preservative oil (linseed oil based) – it soaks in well and remains transparent!
This is a sensible approach, especially since oils stabilize the material without creating a rigid, waterproof layer that can crack when the wood deforms.
Whether oils or varnishes are used: regular maintenance and visual inspections are essential, particularly in areas with high humidity.
In summary: a combination of reducing indoor humidity, maintaining distance from walls, applying a sealant (varnish or oil), and ensuring proper ventilation provides the most effective protection.
