ᐅ How can I effectively protect BILLY shelves in areas with high humidity?
Created on: 3 Oct 2023 08:12
di-elaine5
di-elaine5
3 Oct 2023 08:12
I am looking for reliable and practical methods to protect IKEA Billy shelves from high humidity. Specifically, I have an apartment with a relatively constant humidity level of 65% to sometimes 75%, where the shelves have already started showing slight swelling and deformation.
I want to prevent permanent damage to the shelves, especially since I use them for books and decorative items. What measures are recommended to protect the wood from moisture? Are there special sealants, coatings, or other protective treatments that have proven effective for Billy shelves due to their MDF or particleboard construction?
I would appreciate any advice on prevention, suitable products, or alternative placement options!
TEBILO
3 Oct 2023 08:45
Hello di-elaine5,
Your question is very well formulated and clearly addresses the issue. BILLY shelves are usually made of veneered particleboard, which tends to swell especially in conditions of high humidity and poor ventilation.
First of all, it is important to reduce the moisture content in the surrounding environment, for example with dehumidifiers, since structural measures provide the best foundation. If that is not sufficient, I recommend applying a special sealant to the shelf surfaces and edges.
An effective solution is a clear acrylic or polyurethane coating applied to all visible surfaces and especially the edges, as moisture is most likely to penetrate there. It is important to not just dust off the surface but to lightly sand it to improve adhesion.
Alternatively, water-repellent wood preservatives based on plant oils can be used, applied in multiple layers. These penetrate the boards to some extent while still allowing the material to "breathe," which is important for MDF to minimize deformation.
I would also check whether the shelf is placed directly against exterior walls, as humidity is usually highest there. In this case, small spacers could help relieve the back panel for ventilation purposes.
I am also curious: How long has the shelf been at its current location, and are the deformations already quite noticeable or rather minimal? The intensity of use varies for these shelves, which also affects the level of wear.
Santi
3 Oct 2023 09:07
If the humidity is that high, a dehumidifier is the most effective solution.
Additionally, I would seal all edges and surfaces with clear varnish, as this directly prevents moisture from penetrating.
kieran
3 Oct 2023 09:38
TEBILO schrieb:
Acrylic or PU paint layer applied on all visible surfaces and especially on the edges
This is an essential tip. The edges of the BILLY shelf are particularly vulnerable to moisture due to the manufacturing process, as the particle boards are unprotected there.
Additionally, I want to emphasize that a dry location is fundamental. If the humidity does not consistently remain below 60%, I recommend not only technical solutions such as dehumidifiers but also regular monitoring and, if necessary, the use of silica gel packets inside the shelves.
Moreover, sealing the back panel with a special foil can help if it is not already provided from the factory – it is worth considering this method. Specialized stores offer foils that are vapor-permeable but prevent water vapor from passing through.
KIN42
3 Oct 2023 10:14
I would add that protection is only as good as its application. Several thin layers of a suitable varnish or wood preservative are better than one thick layer. The recommended drying time between coats must be strictly followed.
Additionally, shelves should not be placed too close to cold exterior walls, as condensation tends to occur more in those areas. A small gap allowing air circulation can make a significant difference.
di-elaine5
3 Oct 2023 11:05
TEBILO schrieb:
I’m also curious: How long has the shelf been in place, and are the deformations already quite visible or rather minimal?
The shelf has been in an east-facing room for about 6 months, where the humidity ranges between 65 and 75% in the mornings and evenings – airing alone barely reduces the humidity. The deformations are still minimal, mainly slightly warped doors, but these are noticeable both visually and by touch.
Santi schrieb:
Dehumidifier
I’m considering using a dehumidifier, but only at night, since more ventilation is done during the day.
Thank you all for the painting tips! It’s important to me that the finish doesn’t change the shelf’s appearance too much. Are there clear coatings that are still effective?
