ᐅ How can I reinforce my BILLY doors after installation?
Created on: 12 Nov 2022 16:27
nakenar
nakenar
12 Nov 2022 16:27
Hello everyone, I have a specific question regarding the doors of my BILLY bookshelf from IKEA. The doors seem a bit unstable to me, and I would like to reinforce them afterward without affecting the appearance or having to change the assembly fundamentally. Does anyone know of proven methods or suitable materials to increase stability, especially for versions with glass or plastic panels? I would like to learn how to apply additional reinforcements effectively, ensuring they are durable and as discreet as possible. Perhaps there are accessories or small tricks recommended specifically for BILLY doors? Please also provide advice on tool use, if necessary.
nonpra
12 Nov 2022 17:04
Simply attach small metal brackets on the inside of the doors. This increases stability and is barely visible. Alternatively, a horizontal wooden batten screwed on the inside can also help.
Laukau5
13 Nov 2022 09:18
Hello, I will provide a more detailed answer to your question because the reinforcement of BILLY doors should be considered differently depending on the model. In general, BILLY doors, especially those with glass or plastic panels, are thin and designed more for visual lightness than for robust protection. If you want to increase stability, there are several proven strategies.
1. Internal reinforcement with wooden strips: Here, you cut thin strips (about 1-2 cm (0.4-0.8 inches) wide, maximum 0.5 cm (0.2 inches) thick) to the length of the inside of the door. You can attach these strips directly to the back with small screws or wood glue. Note: It is best to remove the door if possible to make the work easier and avoid screws in visible areas.
2. Metal brackets: As mentioned, small metal brackets provide a good way to stabilize corners and edges. It is important to install them on the inside to avoid affecting the appearance.
3. Backing the panel: If the door has a glass or plastic panel, you can use a thin metal frame along the inside edge. This method is more complex because you will need to partially disassemble the door.
4. Replacing fittings: Installing stronger hinges or adding extra hinges can also help to reinforce the door within the overall system.
Tools you will mainly need are a cordless drill with smaller bits, a chisel, wood glue, possibly clamps for gluing the strips, and fine sandpaper.
I’m curious which exact door version you have? That will make specific recommendations easier and help avoid unnecessary work.
Ianlau
14 Nov 2022 12:33
Laukau5 schrieb:
I would be interested to know exactly which door version you have?
This is really important because BILLY comes with different door materials, and the way you approach reinforcement depends on that.
Generally, I would also recommend carefully checking the existing connections, such as hinges and dowels, before adding any reinforcement. Sometimes loose connections are present from the start and cause unstable doors, which can be fixed with minimal effort.
If that isn’t an issue, you can proceed using the wood strip method. In my experience with BILLY doors that have glass panels, attaching a thin strip of wood along the inside lengthwise worked well. It’s important to use short screws that don’t go all the way through the door to avoid damaging the surface. Small mounting brackets are also very suitable for this, as already mentioned.
For plastic panel doors, you can additionally use silicone adhesive to reduce any vibrations.
If your priority is a discreet appearance and durability, special BILLY door reinforcement kits available from specialist retailers might be an option—they are occasionally available online.
