Hello everyone, I have a rather specific request and hope for your expertise: How can I improve or reinforce the stability of my IKEA Malm furniture afterwards? Specifically, it concerns the bed dressers and especially the drawer units, which have become a bit wobbly over time. I suspect that the joints in the carcass have weakened due to regular use, even though there is no obvious damage. What methods are particularly effective for increasing stability without requiring too much effort or expensive parts? Are there proven techniques you can recommend – for example, additional screws, adhesive methods, or reinforcements with metal brackets? I would appreciate detailed tips, as I would like to do the work myself and want to preserve the furniture without having to replace it entirely.
Hey Poklo, good question! Malm furniture is generally sturdy, but it does have some weak points that can become really annoying after a few years. 🙂
What has worked well for me are metal brackets on the inside corners of the furniture – they’re inexpensive, easy to install, and significantly improve stability. It’s important to attach the brackets on the inside, at the joints, where they won’t get in the way, rather than on the outside.
You can also check the screws and wall plugs: they often loosen over time. Simply tightening screws that aren’t fully screwed in or using larger screws can help.
And if you’re up for some DIY, you can glue wooden strips to the edges on the inside to increase strength.
In my opinion, metal brackets are the most popular reinforcements. Good luck! 😊
Poklo schrieb:
Gibt es bewährte Techniken, die ihr empfehlen könnt – zum Beispiel zusätzliche Verschraubungen, Klebeverfahren oder Verstärkungen mit Metallwinkeln?
To stabilize Malm furniture, I recommend a combination of the following measures:
1. Tighten existing screws and, if necessary, replace wooden or dowel joints with stronger screws and appropriate anchors.
2. Install metal connectors or brackets at particularly stressed points, such as inside corners or drawer slides.
3. Reinforce the back panels with additional wooden boards to protect the cabinet structure from deformation.
4. Apply high-quality wood glue to joints, where accessible, to increase mechanical stability.
With drawers, it is especially important to ensure that the guide rails are securely mounted and do not loosen. In many cases, small locking hooks or metal washers also help improve the stability of the rails.
This method is technically proven and prevents future warping due to load. All solutions should be achievable with standard tools.
Poklo schrieb:
Konkret handelt es sich um die Bettkommoden und insbesondere um die Schubladenelemente
juMira46 schrieb:
Metal brackets on the inside corners of furniture – they’re inexpensive, easy to install, and really improve stability.Well, I think metal brackets are often overrated. Sure, they help, but honestly – isn’t that just a band-aid on a deeper issue? Malm is basically IKEA standard, and if that stuff wobbles, it’s a design flaw that a hammer and brackets won’t really fix.
What makes much more sense is to use reinforced wooden panels or even rebuild the carcass with dowel-reinforced joints instead of just adding brackets. Brackets often spoil the look and create point loads on the wood, which can lead to cracks.
RENMA schrieb:
Reinforcing the back panels with additional wooden boards to protect the carcass from warping.I agree with that. An extra back panel, preferably made of waterproof plywood, really adds a lot of stability. Metal brackets are more of a quick fix if you’re really serious about doing it properly.
Thanks for all the great input so far! 🙂
A quick question about the metal brackets: If I place them in the corners like that, what is the best way to do it without affecting the look or function of the drawers? Are there special brackets that are flatter or easier to conceal?
And regarding the screws and wall plugs – how can I tell if the plugs have reached their limit in terms of stability? Visually, everything still seems properly engaged, but the stability noticeably suffers.
Good point, but I definitely don’t want to tackle the furniture with major construction work right away. I’m looking for a middle ground, more like an optimization and reinforcement within the existing framework.
likuken schrieb:
Honestly – isn’t this just a band-aid on a deeper problem?
