ᐅ How can I reinforce IKEA Besta units to safely support heavy books?
Created on: 5 May 2024 18:37
Pusan58Hello everyone, I have a question about my current project: I want to reinforce my IKEA Besta furniture, especially the shelves, so they can securely hold very heavy books over time without the shelves bending or the structure becoming unstable. The shelves are relatively thin and designed for light to medium loads. I’m interested in reinforcement options that remain visually subtle and do not limit functionality. For example, I’m considering adding extra braces, metal brackets, or replacement shelves, but maybe there are better solutions? It’s important that the shelves stay stable, don’t require major construction work, and are ideally affordable. Does anyone have experience or tips on how I can upgrade my Besta furniture to safely support heavy books? Thanks in advance!
Pusan58 schrieb:
I’m interested in reinforcement options that remain visually discreet and don’t compromise functionality.Hey Pusan58, great question! IKEA furniture is usually quite clever, but it can sometimes struggle with heavy loads. A classic solution, as you mentioned, is metal brackets under the shelves—they add a lot of stability and are usually hidden if you place them behind the back panel.
You can also reinforce the back panel or replace it with plywood, which provides lateral stiffness. Another less common idea is to swap the original particleboard shelves for thicker wooden boards (e.g., plywood or MDF, 18mm (0.7 inches)) which are sturdier and won’t sag.
Important: Always secure screws and brackets firmly to ensure everything holds well. With a combination like this, you should be able to reinforce your bookshelf easily without it looking like a workshop fix 😉 Good luck!
meGreg schrieb:
A classic solution, as you already mentioned, is metal brackets under the shelves – they provide a lot of stability and are usually invisible if you hide them behind the back panel.To add: It is especially effective to reinforce the shelves with so-called steel "L-brackets" mounted directly on the side panels and under the shelves. These can significantly increase the load capacity by preventing the shelves from sagging.
Additionally, I recommend using plywood boards at least 8-10 mm (0.3-0.4 inches) thick as a replacement for standard shelves – these are much stronger and less prone to bending. Alternatively, you can use a shelf panel made of chipboard or MDF, provided it is securely fixed.
Another important step is to secure the entire shelving unit to the wall to prevent tipping. This not only improves safety but also makes the overall structure more rigid.
In summary:
- Attach L-brackets to the sides and undersides
- Install stronger shelves (plywood/MDF)
- Secure the shelving unit to the wall
These measures are effective without requiring major modifications to the furniture. They are also cost-effective, as brackets and materials are affordable.
Pusan58 schrieb:
I want to reinforce my IKEA Besta furniture, especially the shelves, so they can safely hold very heavy books over the long term, without the shelves sagging or the structure becoming unstable.Great project! I had exactly the same issue with my Besta shelf, and this solution worked really well!
I replaced the shelves with sturdy 18mm (0.7 inch) plywood panels and also added small metal brackets on the side panels that support the shelves from underneath. This spreads the load to the side panels and makes the shelves rock solid! 😊
Additionally, I replaced the back panel with a plywood board that I screwed to the sides. This made the entire construction much more stable. My shelf can now easily hold almost 40 kg (88 lbs) per shelf!
If you’re a bit handy, this is a great method you can do in one afternoon. If you have any questions, just ask—I’m happy to help :-)
