I have a fairly specific problem with my BILLY shelves from IKEA. The shelves start to sag over time under moderate load, which obviously doesn’t look good and also doesn’t seem as stable as I would like in the long run. Specifically, I’m looking for the best way to reinforce the shelves against bending without having to buy completely new shelves or ruining their appearance.
I’m looking for practical and sustainable solutions that can be done with a manageable effort—such as reinforcements that can be screwed or glued underneath the shelves, or other methods you have experience with.
Does anyone here have good tips or even full guides on how to effectively and permanently strengthen BILLY shelves? Especially interested in suggestions that noticeably increase load capacity and are as discreet as possible.
Thanks in advance for your help!
Hello Erick, I completely understand your concern; sagging of BILLY shelves is unfortunately a common issue.
Basically, the stability depends on the shelf material and the load span. BILLY shelves are often made of particleboard or MDF panels, which can sag under excessive weight.
First, I recommend not loading the shelves too broadly—place heavy items preferably toward the sides rather than in the center.
There are several ways to reinforce the shelves:
1. Aluminum angles or U-profiles: You can screw these under the shelf. They are sturdy, relatively unobtrusive, and significantly increase load capacity.
2. Solid wood reinforcement strips: Here, you can intentionally attach a strip under the middle of the shelf to prevent sagging. It is important that it is precisely fitted and securely fixed.
3. Additional center support by inserting a vertical strip between the shelf bottom and the top of the unit. This support directly takes the load.
Personally, I find the combination of a center support and a crosspiece very effective.
When fastening, be sure to pay attention to the type of screws used to avoid damaging the shelf itself.
If needed, I can gladly provide information on materials and where to source them.
Thank you, benon, for the detailed advice.
Additionally, I would recommend considering the type of load when choosing reinforcement. If the shelf board is frequently subjected to concentrated heavy loads, solid wood battens are preferable, as they distribute the load more effectively.
This is definitely a practical solution, especially if discreet reinforcement is desired.
Another option is to place the shelf board on a thin metal pipe or a cross brace, which can be kept invisible by matching the color.
If possible, make sure that the reinforcement does not affect the shelf height, so the appearance is maintained.
benon schrieb:
Aluminum angles or U-profiles: You can screw these under the shelf board...
Hey Erick!
I had exactly the same problem with my BILLY shelves and know how annoying it is! But I found a really simple solution: I screwed small steel brackets under the shelves and also glued a thin MDF strip centered underneath the shelf boards. It holds firmly and almost looks like it was done at the factory 🙂
Yes, that was exactly my goal too. It’s amazing how such small adjustments can make a big difference! Since then, nothing wobbles and the shelves look great.
I just want to encourage you – this really works well, and with a bit of skill anyone can do it themselves! Good luck, you’ll manage!! :-)
Erick schrieb:
...how I can best reinforce the shelves against sagging without having to buy completely new boards or ruining the appearance.
