I’m facing the challenge of fitting Ikea Platsa units into a very tight space and would appreciate advice on how to best redesign the furniture to make the most of the available area. Specifically, it’s a small niche about 1.20 m (4 feet) wide with limited depth, where I want to create storage without making it feel cramped or restricting movement.
Has anyone had experience adapting Platsa for such narrow spaces? What solutions for cabinet layout, door or front options would you recommend? Are there any tips on modularity I should keep in mind? I’m looking forward to concrete suggestions or examples of how you’ve solved a similar situation.
Hello Ezelsin,
You want to redesign Ikea Platsa in a tight space – that is quite an interesting challenge. Here is a detailed approach:
1. Carefully analyze the measurements: Make sure all parameters are accurate (width, depth, height, as well as doors or windows).
2. Module selection: Platsa offers 35 cm (14 inches) deep modules, which fit better into narrow recesses. Combine narrow and tall modules to make efficient use of the space.
3. Fronts: Choose sliding doors or even open shelves to avoid making the space feel cramped. Glass doors can also visually increase the sense of openness.
4. Interior design: Use the modularity for custom drawers, drawer inserts, clothes rails, and boxes to optimize storage space.
A tip from me: When assembling, avoid installing the modules flush against the walls; leave small gaps to compensate for unevenness. If you have precise gaps between walls, custom-cut shelves can also be a good option.
Can you specify exactly what you want to store? Clothes? Books? Other items?
Thanks in advance for the helpful advice!
The main goal is to store clothing and a few boxes with seasonal items. I prefer closed fronts to avoid a cluttered look but am also leaning toward certain glass elements to keep an airy feel.
That’s a good point, but considering budget and availability, I think Platsa is a realistic option. It definitely needs to be practical and durable.
Would you recommend using individual units or building a continuous system to maximize the use of the small niche?
kasan schrieb:
How sure are you that Platsa is the best solution for your tight niche?
There are two aspects that I believe are essential to consider: flexibility and accessibility.
In very tight spaces, it is worth using individual modules, as these can be more easily adapted to the available space and rearranged later if needed. Often, a combination of tall and low cabinets proves sensible to ensure both volume and ease of use.
I tend to recommend individual modules that can be used flexibly – this avoids unnecessary empty spaces and allows for adjustments when needs change.
Ezelsin schrieb:
Would you rather install individual modules or build a continuous solution, especially to make the most of a small niche?
Gloriagl1027 Mar 2024 16:23In short: For tight spaces, it really helps to choose compact modules, use sliding doors, and incorporate drawers or inserts inside wherever possible.
When it comes to clothing, hanging rods in lower modules are also practical.
Use open shelves where you need frequent access, and closed fronts for less frequently used items.
One more technical note for planning:
The maximum height for Platsa currently is about 201 cm (79 inches), which can be important in smaller rooms since you cannot build endlessly upwards. Use this information in your planning so you don’t overestimate the available storage space.
In very narrow recesses, you might also consider removing the back panel and using the modules as room dividers, which can often add flexibility to the space.
Additionally, Platsa modules are compatible with various baseboard heights—you can adjust these to make optimal use of the space without creating trip hazards.
Do you have any other structural features (hollow walls, radiators, window frames) that might limit the design?
Hello Ezelsin,
you could almost say this sounds like a case for the "Platsa magic wand"! 😉
Jokes aside, with such small niches, attention to detail often helps: sliding doors are a perfect solution, and if you prefer closed fronts as you mentioned, try mixing different front materials to avoid a heavy look – frosted glass fronts, for example, are a great compromise.
Also, don’t place the modules too close together; leaving some space creates a more open and calm feeling. You might want to experiment with small furniture casters if you need to move the modules around easily without much effort.
Good luck with your Platsa Tetris!
