ᐅ How can I customize Ikea Pax wardrobes for different storage purposes?
Created on: 17 Jan 2023 09:37
RengiHello everyone,
I am planning to modify my existing Ikea Pax system for various storage purposes and am looking for versatile and practical ideas. Specifically, I want to know how to adjust or supplement the individual modules – such as frames, doors, drawers, and interior fittings – to best meet different needs.
For example, I am interested in how to design the Pax system so that it works as a wardrobe for clothing, but can also be efficiently used for storing shoes, accessories, or even office supplies. What technical terms should I be familiar with, and which accessories from Ikea or third-party suppliers are particularly useful?
Are there recommendations on how to integrate dividers, hooks, or customizable compartments with minimal effort, without compromising the flexibility of the system? I am also interested in door modifications, such as glass inserts or makeshift storage options.
A practical approach is important to me that does not require extensive DIY skills, as I am not very experienced in home improvement.
I look forward to your experiences, tips, and links to suitable solutions or customization options that have proven successful.
Hello Rengi,
Your thoughtfully formulated and specific question is really great—I appreciate that you are already considering the different storage purposes in detail!
First, I recommend viewing the Pax system entirely as a modular frame. At Ikea, the basis is usually the individual carcasses with various heights and widths, into which you can install interior fittings:
- For clothing, hanging rods are suitable and can be mounted at adjustable heights to create space for longer or shorter garments.
- Drawers and shelves are perfect for organizing smaller clothing items or accessories. Boxes or baskets can also be integrated well this way.
- Specifically for shoes: Ikea offers entire shoe shelves or removable inserts. Here, the depth of the Pax carcass is crucial—usually, you should use the 58 cm (23 inches) deep frame to accommodate larger shoes.
- Accessories such as hooks, pull-out tie or belt racks can be installed relatively easily inside (for example, with screws or, in some cases, using clamp mechanisms).
Regarding the doors: Glass inserts can be retrofitted, but this often means you either use original Ikea parts designed for this purpose or turn to third-party products, some of which already offer prefabricated systems. Covering them with plexiglass or films is possible but requires some craftsmanship.
You maintain the best flexibility by using interior fittings that are movable, not permanently fixed. For example, with adjustable shelves, you can change the interior layout later with little effort.
One last tip: If space and budget allow, it’s worthwhile to configure the Pax system online with the Ikea planner before purchasing. This way, you can try out different combinations and get a feel for the space requirements and practical interior divisions.
Perhaps you could add for how many people the system is intended and whether you want to store clothing or also sports equipment/storage items? Then I can respond more specifically to your needs.
Surela schrieb:
Regarding the doors: You can retrofit glass inserts, but this usually means either using original Ikea parts designed for this purpose or opting for third-party products, some of which offer pre-made systems.I wanted to revisit this topic because I recently redesigned my Pax wardrobe and realized how much small changes can enhance the entire system.
What was important to me was that the storage should not only be practical but also visually appealing. That’s why I chose internal drawers with tinted glass fronts, which not only look stylish but also create a sense of openness in the room without exposing everything.
Additionally, I installed magnetic hooks on the inside sidewalls for smaller accessories. They hold really well and can be repositioned at any time. This makes each compartment much more flexible because you can keep items like belts, jewelry, or scarves easily accessible.
My personal highlight, however, is the LED strips I installed in the frame. They can be controlled by remote and are a great help when looking for something quickly in low light, for example in the early morning. A simple trick, but extremely useful.
I’m curious if your room layout imposes certain limitations or if the system stands freely in the space? That can sometimes affect which types of doors or extensions make sense.
Surela schrieb:
You maintain flexibility best by using interior fittings that are movable, so not permanently fixed.This is an essential point, and I would like to add: adjustable shelves and shelves with grid holes are typical for Pax and crucial for adaptability. The dimensions of the components are standardized, allowing easy combination and retrofitting.
It’s also worth planning special solutions for different storage needs:
- Slanted shelves are helpful for shoes because they provide better visibility and more space than flat shelves.
- Small containers and boxes that can be integrated into drawers work well for office supplies.
- For clothing, I recommend a combination of hanging rods at different heights (e.g., separate ones for shirts and coats), complemented by shallow drawers for underwear and socks.
The doors in Pax can be modularly exchanged, allowing a mix of open elements and doors with glass panels or mirrors. This can also create an open feeling in the room if desired.
The system is extremely robust; the load capacity for shelves is specified by Ikea (usually 15–25 kg per shelf) and should be considered when distributing weight.
In summary: planning with the Ikea Pax planner, choosing modular interior fittings, considering individual storage needs, and using system accessories (integrated or retrofittable elements) are the best ways to use Pax efficiently and flexibly.
