ᐅ How can I modify IKEA Metod kitchen cabinets for accessible living?
Created on: 1 Jan 2019 08:23
RickeyreGood morning everyone,
I am currently working on modifying my IKEA Metod kitchen units to create an accessible kitchen. My goal is to design a kitchen that is as functional and accessible as possible for wheelchair users or people with limited mobility. This naturally includes considerations like lower countertops, easier access to cabinets, and practical adaptations such as pull-out elements or handleless openings.
Has anyone here had experience or ideas on how to specifically adapt IKEA Metod kitchen modules for accessible living? Which components are particularly suitable or might need to be added or replaced? I am especially interested in how to optimize storage space without compromising accessibility.
I look forward to your tips and concrete suggestions!
marcosku521 Jan 2019 11:07Rickeyre schrieb:
My goal is to create a functional and accessible kitchen suitable for wheelchair users or people with limited mobility.Hey, that’s a really important project, hats off! With IKEA Metod, I recall many cabinets are modular – which makes designing an accessible layout easier. It’s definitely important to choose cabinets with pull-out drawers instead of doors, so you can reach everything without straining.
- Handleless fronts with a tip-on system make opening easier without much force.
- For worktops, consider lowering them to a wheelchair-friendly height of about 85 cm (33.5 inches) since standard heights are often higher.
- Open base cabinets with space underneath for legroom can be especially valuable.
Important: Plan enough clearance, at least 120 cm (47 inches) aisle width, if you’re working with a wheelchair. Also, you might want to include a height-adjustable table or cabinet fronts that can be customized individually.
Sure, these are some “special features,” but with Metod you can achieve a lot.
Rickeyre schrieb:
I am particularly interested in how to optimize storage space without restricting accessibility.To optimize storage space while ensuring accessibility, I recommend the following measures for IKEA Metod kitchen furniture:
- Use pull-out drawers instead of traditional cabinet doors to allow direct access to contents without bending deeply.
- Install adjustable shelves so that the optimal reach zone can be set according to the user.
- Integrate corner carousels or swing-out drawers to maximize storage space while keeping it accessible.
- Adjust base cabinet height, ideally to about 70–75 cm (28–30 inches), to provide enough legroom for wheelchair users.
- Consider easy-to-operate opening mechanisms, such as soft-close and tip-on systems, for simpler access.
These measures are ergonomically proven and compatible with the modular systems of the Metod series.
marcosku52 schrieb:
For countertops, I would consider shortening them to a wheelchair-friendly height of about 85 cm (33.5 inches), as the standard is often higher.I would like to raise a critical point here: Isn’t the standard height of IKEA Metod countertops often around 91 cm (36 inches)? Lowering them to 85 cm (33.5 inches) makes sense, but it is not always technically straightforward since the base cabinets need to be adjusted.
Additionally, we should keep in mind that not all users have the same needs; the optimal height can vary significantly. Therefore, I recommend considering solutions like height-adjustable countertops or mobile kitchen modules that offer flexibility.
Samir schrieb:
Integration of corner carousels or swing-out drawers that maximize storage space while remaining accessible.That is a good approach, but for genuine accessibility requirements, it should also be examined whether such swing-out drawers are not too complex or difficult to operate. It would be helpful to base this on practical experience or ergonomic studies.
I suggest prototyping the planned changes first (e.g., with modules on casters at different heights) before undertaking major kitchen renovations.
