Hello everyone!
I recently purchased some IKEA Brimnes furniture, mainly dressers and bed frames, and now I am thinking about recycling. Since these pieces are made from a combination of particleboard, MDF, and some laminated surfaces, I am wondering about the best way to recycle them in an environmentally friendly way.
I am especially interested in concrete steps: How should such furniture be disassembled? Are there specific recycling centers that accept these composite materials? And what about the possibility of reusing individual parts like metal fittings or screws separately?
I want to avoid having the furniture simply thrown in general waste or – even worse – ending up in a landfill. Any helpful tips or personal experiences would be greatly appreciated, as sustainability is very important to me when it comes to furniture.
Thank you in advance for your support!
FOFOJAN schrieb:
I’m also a bit concerned about the health aspects when working with particle boards.That concern is justified. Particle boards contain formaldehyde and other substances that can be released during cutting and sanding.
- Mandatory: wear a protective mask (FFP2 or better).
- Safety glasses and gloves should also be used.
- Use tools that produce less dust, such as plunge saws with dust extraction systems.
If upcycling is relevant for you, I recommend sealing surfaces that will have frequent contact with a varnish or wax before use, to minimize the release of harmful substances.
How large are the pieces of furniture? It might be practical to salvage only individual parts that can be easily used for DIY projects.
FOFOJAN schrieb:
Upcycling is an exciting idea for me.It’s great that you bring this up!
Brimnes furniture often involves a lot of effort to build, so individual components can definitely be reused:
- Drawer fronts can be repurposed as small shelves or trays
- Thin wooden back panels are perfect for craft projects
- Metal fittings like hinges and screws can be saved for repairs
If you have some DIY skills, furniture modifications are also worthwhile, for example turning a dresser into a bench or creating shelf inserts.
You just need to carefully dismantle the parts and check that they are not damaged.
I can also recommend contacts who accept furniture donations and handle upcycling projects, in case you don’t want to use everything yourself.
