ᐅ How can I rearrange Ikea Metod kitchen cabinets to optimize smaller spaces?
Created on: 25 Aug 2020 18:37
hakantau8
hakantau8
25 Aug 2020 18:37
I have an Ikea Metod kitchen that is currently installed in a rather small room. Due to the limited space, I am considering rearranging the kitchen units to make better use of the area while maintaining a functional kitchen layout. My question is: How can I best rearrange Ikea Metod kitchen units for smaller spaces?
I am especially interested in tips for optimizing space usage, suitable layout options, possible modular adjustments, and ideas on how to effectively design corners or narrow passages.
I look forward to your advice and experiences, especially regarding modularity and thoughtful planning in small kitchens. Thanks in advance!
PAR63
25 Aug 2020 19:06
Hello hakantau8,
For rearranging Ikea Metod kitchen cabinets in small spaces, I recommend the following structured approach:
- First, take precise measurements of the room. This is essential to plan the cabinets accurately.
- In small kitchens, an L-shaped or U-shaped layout is often helpful, as it uses corners effectively and keeps walking distances short.
- Use tall cabinets that reach up to the ceiling to maximize storage space. Ikea Metod offers suitable wall cabinets for this purpose.
- Corner solutions like corner carousels or pull-out trays are practical to avoid dead angles.
- Plan enough countertop space and at least 60 cm (24 inches) wide base cabinets for kitchen appliances.
- Consider tall cabinets for the oven and refrigerator to increase available countertop space.
Common mistakes include cabinets that are too wide and overcrowd the room or insufficient clearance for movement. Make sure to allow at least 90 cm (35 inches) of walkway width in the kitchen.
In summary: precise planning, optimal corner use, and vertical storage are key for smaller spaces.
If you like, I can also provide an example layout or suggest common cabinet combinations.
hakantau8
25 Aug 2020 20:12
PAR63 schrieb:
First, you should take precise measurements of the room. This is essential for planning furniture that fits perfectly.
Thanks for the start, that is absolutely right. I have already taken accurate measurements. The room is just under 3.2 meters (10.5 feet) wide and 2.7 meters (8.9 feet) long, a rectangle with a door on the short side. Currently, I have a simple kitchen unit installed along one wall, but it feels quite cramped.
PAR63 schrieb:
For small kitchens, an L- or U-shaped layout is often helpful because it uses corners efficiently and keeps walking distances short.
I could implement the L-layout along the long wall and one of the short walls, but the door limits the space on the short wall.
PAR63 schrieb:
Corner solutions such as corner carousels or pull-out corner units are useful to avoid dead corners.
My question would be: Is there a particular type of pull-out corner unit that works especially well in small Metod kitchens?
Maybe there are more tips on this. Looking forward to your advice!
Sinan-meo
26 Aug 2020 07:44
Adding to what has already been said: For smaller rooms, it makes sense to adjust the countertop height to ergonomic factors as well, since there is less space available and you want to work as efficiently as possible.
I also recommend using open shelves or half-height cabinets selectively, as they can make the room appear smaller visually. Instead, opt for closed fronts to create a calm and cohesive look.
When it comes to corner cabinets, I find that using pull-out drawers instead of traditional hinged doors is more advantageous. This provides better access, which is invaluable in tight spaces.
One last tip: Make use of the inside of cabinet doors, for example with hanging racks for spices or small tools. This creates extra storage without sacrificing floor or shelf space.
Leland
26 Aug 2020 08:11
In short: L-shaped layout with a 40cm (16 inch) corner cabinet and as many pull-out drawers as possible. Use tall cabinets for the refrigerator and oven to save valuable space.
pikin
27 Aug 2020 14:53
In my experience, when reorganizing Ikea Metod kitchen cabinets in small spaces, the modular adaptability is a crucial factor. The Metod series offers various base units in different widths (20, 40, 60 cm (8, 16, 24 inches), etc.) that can be combined effectively.
It is important to arrange the cabinets so that the work areas are clearly defined: sink, cooktop, and countertop should be placed in a logical sequence.
I also recommend planning corners with so-called Magic Corners or LeMans pull-outs instead of traditional corner cabinets. This improves accessibility and saves time during use.
Additionally, space for appliances should be taken into account, and if necessary, special inserts for the Metod drawers can be used to keep things organized.
Overall, I advise using a planning program (Ikea offers one) to visualize different layouts, making it easier to avoid bottlenecks.
