ᐅ How can I adjust the doors of an Ikea Hemnes wardrobe?
Created on: 24 Aug 2021 09:12
Knudlu
I have an Ikea Hemnes wardrobe with double doors, and over time the alignment has shifted slightly. The doors no longer close flush; on one side, the door sags a little, causing a gap. I noticed that the hinges have small adjustment screws, but I’m unsure how to properly adjust them without damaging the door or affecting its functionality.
Could someone provide a detailed guide on how to correctly realign the Hemnes wardrobe doors? I’m especially interested in information about:
- The types of screw adjustments (horizontal, vertical, depth)
- The recommended sequence of adjustment steps
- Tips to avoid causing any damage
- Necessary tools
Thanks in advance for any advice!
SUBEN60
25 Aug 2021 09:12
Knudlu schrieb:
For me, the right door at the bottom is slightly sagging, but it fits tightly at the top.
This is a typical sign that vertical adjustment is needed. Due to the sagging, the door usually lowers at the bottom edge. To correct this, you should loosen the screws on the hinge mount attached to the cabinet and move the door slightly upwards. Then be sure to tighten the screws again.
Knudlu schrieb:
Could it be that the screws loosen over the years, causing the adjustment to be lost?
Yes, this often happens due to material stress and minor vibrations. It is not uncommon to need regular readjustment every few months.
My tip: If needed, apply small drops of threadlocker (not resin-based) to the screw threads if you want the settings to hold longer.
emmett
25 Aug 2021 11:47
If the door sags at the bottom, first try adjusting the vertical alignment. Slightly loosen the screws on the hinges, move the door upward, and then tighten the screws again. Next, check the depth with the front screw of the hinge to ensure the door closes flush.
derrick34
26 Aug 2021 14:08
Be careful not to overtighten the screws. Excessive torque can damage the plastic threads of the hinges. Adjust carefully and check how the door closes after each small adjustment.
TARAON
26 Aug 2021 17:32
Here’s a handy tip: If you’re having trouble adjusting the door on your own, ask someone to hold it steady while you make the adjustments. This way, you can quickly and easily test until everything fits perfectly – almost like having a mini closet partner!
Otherwise, don’t worry, Hemnes is sturdy, and with the right fine-tuning, you’ll definitely be on the safe side.
