I have an Ikea Hemnes wardrobe with double doors, and over time the alignment has shifted slightly. The doors no longer close flush; on one side, the door sags a little, causing a gap. I noticed that the hinges have small adjustment screws, but I’m unsure how to properly adjust them without damaging the door or affecting its functionality.
Could someone provide a detailed guide on how to correctly realign the Hemnes wardrobe doors? I’m especially interested in information about:
- The types of screw adjustments (horizontal, vertical, depth)
- The recommended sequence of adjustment steps
- Tips to avoid causing any damage
- Necessary tools
Thanks in advance for any advice!
- Necessary tools
Hello, the Hemnes cabinet doors are equipped with clip-on hinges. You can adjust the door on three axes:
- Horizontal: loosen the screw near the hinge and slide the door sideways
- Vertical: move the hinge up or down on the cabinet frame
- Depth: use the small screw at the front of the hinge to adjust the gap
Tool: Phillips screwdriver. Always make slight adjustments first, then test.
For precise adjustment of the Ikea Hemnes cabinet doors, I recommend the following structured approach:
- First, open the door and carefully inspect the hinges. Hemnes doors use concealed clip hinges with three adjustable screws each.
- Use a Phillips screwdriver to slowly adjust the screw for horizontal shifting (usually closer to the cabinet frame) to align the door sideways.
- Then check the vertical adjustment: loosen the door slightly and move it up or down along the screw holder on the cabinet body.
- Finally, make the depth adjustment using the small screw at the front part of the hinge. This ensures the door closes flush without gaps.
Important: Make each screw adjustment in small increments only and move the door after each adjustment to check the fit. Suitable tools are a medium-sized Phillips screwdriver and a small piece of chalk to mark positions.
Damage to wood or fittings is practically avoided with this controlled procedure. If the door sags, be sure to counteract using the vertical adjustment.
I know the problem when doors suddenly don’t close properly anymore. It’s really frustrating, especially when you’re not sure how to assess the situation yourself. In my experience, I first considered whether the hinges might be bent or loose. When I carefully tightened the screws, it worked surprisingly well. A bit of patience helps a lot, even though it can be frustrating at times.
If you’re unsure how much to turn each screw: start with half a turn and then proceed slowly in quarter turns. You can always turn it back if needed. Good luck – these small adjustments really pay off!
Briefly and to the point: Hemnes hinges have three adjustment points. For horizontal and vertical adjustments, you need to loosen the hinges and move the door. For depth adjustment, there is a small screw at the front. If you notice that the door is hanging unevenly, adjust the vertical position first.
Turn the screws only slightly.
Thanks for the answers so far!
@RENMA: Your structured guide sounds very helpful. Could you briefly explain how to tell whether I should focus more on horizontal or vertical adjustment? In my case, the right door sags slightly at the bottom but fits tightly at the top.
Is there a quick method to check for sagging and how it affects the individual adjustment steps?
Also, is it possible that the screws loosen over time, causing the adjustment to be lost?
