ᐅ How can I quickly disassemble IKEA Platsa furniture?
Created on: 22 Oct 2022 08:17
bole6
Good morning everyone, I need your experience: How can I quickly disassemble IKEA Platsa furniture? I have several combined cabinets that need to be rearranged now. It is important to me to find a method that protects the floor but also saves as much time as possible. Does anyone have tips on where to start first or if special tools can make the job easier? I have already tried to loosen the metal connectors without instructions, but it doesn’t go very smoothly. Details about screw types or other connections would also be helpful. I appreciate any advice!
pikin
23 Oct 2022 09:55
Summary of the best tips for quickly and safely dismantling IKEA Platsa:
- Remove the fronts first (usually by gently pulling and loosening screws on the inside)
- Take out drawers and shelves for easier handling
- Use the appropriate screwdrivers (Torx T20 very common, otherwise flathead or Phillips)
- Carefully unlock metal connectors (cam locks) with the right tool
- Remove the back panel last to maintain stability
- Gently pull modules apart, do not use force
- Label parts during disassembly or stack them systematically for smooth reassembly
This approach is based on the design of all Platsa versions known to me and ensures an efficient demolition.
Alberto51
23 Oct 2022 11:07
pikin schrieb:
This approach is based on the systematics of all Platsa variants known to me and ensures efficient disassembly.
Thank you for the clear summary. That reassures me a lot, as I will be moving soon and was worried about completing everything as quickly as possible without damage. I will report back when I have the chance to say how well it worked.
bole6
24 Oct 2022 07:29
I wanted to thank you again for the great support here! With your tips, I am already much more confident and faster in dismantling the Platsa modules than I initially expected. Today, I will focus on removing the metal connectors and have all the tools ready. If I encounter any other issues, I will get back to you with questions.
Jukin
24 Oct 2022 08:02
bole6 schrieb:
If I encounter any other problems, I will get back with more questions.
Gladly, we will continue to support you. It is important to stay calm and proceed methodically. I wish you much success and enjoyment with your work!
