ᐅ How can I quickly disassemble and reassemble Ikea BRIMNES furniture when moving?
Created on: 3 Nov 2022 08:37
Aykutto
Aykutto
3 Nov 2022 08:37
I am about to move and own several pieces of furniture from the IKEA Brimnes series, which I want to disassemble as quickly as possible and then reassemble afterwards. Most of the furniture consists of cabinets, dressers, and bed frames, which often involve many screws and connectors. My question is: What efficient yet gentle techniques or tools do you recommend for quickly taking apart BRIMNES furniture without making later adjustments or reassembly more difficult? Are there optimal steps to stay organized during disassembly so that the assembly after the move goes as smoothly as possible? I look forward to practical tips and experiences to help structure the process in the best way.
Jeffon
3 Nov 2022 09:14
The most important tip for quickly disassembling and reassembling BRIMNES furniture is to follow a systematic approach. It is best to use a cordless screwdriver with the appropriate set of bits to save time. Screws and small parts should be stored during disassembly in labeled bags or small containers—ideally separated by furniture piece. Note or photograph each step during disassembly, as this will make the later reassembly much easier. Always start with larger, load-bearing components before removing smaller elements. Avoid losing screws and check all parts for any damage or deformation before reassembling.
TEBILO
3 Nov 2022 10:22
Jeffon schrieb:
The most important tip for quickly disassembling and reassembling BRIMNES furniture is a systematic approach.
Absolutely right, here is a detailed method that has worked well for me:
1. Preparation: Before disassembly, gather all necessary tools, ideally a cordless drill, Phillips and flathead screwdrivers, a rubber mallet, and tape.
2. Documentation: Take photos of each disassembly stage, especially for complex connections. Create a numbered list of parts and screws.
3. Sorting screws: Use small containers or ideally screw organizers to store all screws numbered and separated by components.
4. Disassembly order: For BRIMNES furniture, I recommend removing the shelves first, then carefully detaching the back panels (these are often made of thin particleboard), and finally taking apart larger sections.
5. Protective measures: Cover parts that might rub during the move with blankets or bubble wrap.
6. Transport: Pack flat parts upright and cushion all wooden components well.
If you want more practical advice on specific steps, feel free to ask. It’s especially important to know which pieces of furniture are involved, as BRIMNES is a series with different models.
Aykutto
4 Nov 2022 07:51
TEBILO schrieb:
It would be especially important to know which exact pieces of furniture are involved, as BRIMNES is a series with different types.
Good point, thanks! Specifically, it mainly concerns the BRIMNES bed frame with the drawers underneath, a BRIMNES chest of drawers with four drawers, and two smaller cabinets from the same series. The bed frame is naturally the biggest item. How do you handle removing the drawers without damaging the runners? And the fasteners on the bed have already been used quite a few times, so I don’t want to risk anything breaking.
Dirkmin
4 Nov 2022 09:03
Aykutto schrieb:
How do you handle removing the drawers here without damaging the runners?
The drawers in BRIMNES units usually have metal runners that can be released with a gentle lever or push motion. I recommend fully pulling the drawers out before removal and then locating the release mechanisms on the runners—often small plastic levers on the sides that you need to press or lift carefully to detach the drawer. Avoid using excessive force, as the runners are sturdy but can be sensitive to too much pressure.
Aykutto schrieb:
And the connectors on the bed have been used quite a bit already, so I don’t want to risk breaking anything.
Connectors on frequently used furniture can develop slightly worn threads over time. When disassembling and reassembling, it’s best to use a cordless drill with adjustable torque settings to control the tightening and loosening. If you notice a thread becoming stripped, you can carefully retighten it with the appropriate Allen key or by hand if necessary, but avoid overtightening or applying excessive force.
BLAKEO
5 Nov 2022 14:42
Dirkmin schrieb:
The drawers in BRIMNES are usually equipped with metal sliding rails that can be released with a gentle lever or push motion.
I would question whether quickly disassembling and reassembling IKEA furniture of this kind is generally the best idea. Especially with furniture that has many screw connections and particleboard components, the risk increases that stability will decrease with each disassembly. Instead of focusing primarily on saving time, the aspect of the furniture’s durability should be taken into account.
Aykutto schrieb:
the fasteners on the bed have been used quite often already; I don't want to risk something breaking.
In such cases, it might be worth considering replacing damaged fasteners or reinforcing them with special wood dowel adhesives. Quick work can be helpful, but material fatigue should not be overlooked. Ultimately, quality during reassembly is the most important factor.
