ᐅ How can I protect Malm furniture?
Created on: 24 Aug 2021 09:12
LEAR41
LEAR41
24 Aug 2021 09:12
Good morning everyone,
I own several IKEA Malm furniture pieces, mainly dressers and nightstands, which I would like to protect for the long term. My main concerns are scratches, wear and tear from daily use, and possible water stains, since glasses of water or flowers are occasionally placed on the surfaces. I am also wondering how to best protect the white finish from yellowing caused by sunlight.
Specifically, I am interested in which protective methods have proven effective—for example, special varnishes, films, waxes, or other sealants that do not negatively affect the appearance but are durable at the same time. Are there also things one should avoid to prevent damaging the surface?
I look forward to your recommendations and experiences!
elgla
24 Aug 2021 11:07
Hello LEAR41,
I’m familiar with your dilemma, as I have been using Malm dressers for years and always try to keep them as intact as possible. It’s really frustrating when even small scratches stand out because the surface is so smooth and light.
Here, I can only recommend avoiding placing the furniture directly in sunlight whenever possible or installing UV-protective window films. I don’t use any films on the furniture myself because I often rearrange it, but for long-term prevention, that’s probably the best option.
Regarding surface treatment, I’ve had good experiences with furniture wax. It provides a light protective layer that helps prevent water stains without affecting the appearance. However, it should be reapplied regularly—I do this about every few months. Using coasters and felt pads under the legs also helps prevent scratches and unsightly marks.
I would be cautious about plastic films or thicker covers; they often don’t look good and can leave unpleasant edges if left on for a long time.
I hope this helps you! 🙂
enrique7
24 Aug 2021 13:56
Interesting post by elgla.
However, I have questioned this a bit: Is furniture wax really the best solution for Malm furniture? The surfaces are mostly coated with a melamine resin, which should actually be durable and easy to maintain. An additional wax layer could alter the original finish or wear off over time, causing uneven gloss.
elgla schrieb:
I don’t use any protective film on my furniture because I move it around often; for long-term use, that’s probably the best prevention.
I find that interesting, because frequent moving could cause additional wear, especially with furniture sliding on the floor.
What do you think about special UV-protective varnishes or clear coats that can be applied additionally to protect the original surface? Do you have any experience with this, especially for painted or melamine-coated surfaces like those on Malm? Such a solution might be more durable and provide real protection against yellowing and wear.
LUISABEL
24 Aug 2021 17:03
Regarding the discussion on protective measures for Malm furniture, I would like to add the following:
The surfaces of the Malm series are mainly made of particleboard with a melamine resin coating. This coating is relatively resistant to scratches and moisture but is not indestructible. Liquids should still be wiped off immediately, as standing water or other fluids can sometimes damage the edges.
In fact, applying furniture wax or similar products is not necessarily recommended for melamine resin surfaces, as they do not adhere well to the smooth surface and can easily appear uneven or leave stains.
Better results can be achieved with a damp, lint-free cloth and mild dish detergent. For UV protection, room-side measures such as curtains or UV protection films on windows are advisable, since professional UV clear coats are difficult for private users to apply and are often incompatible with melamine surfaces.
In conclusion, coasters, table runners, and regular gentle cleaning are the most effective and practical protective measures.
kemeo68
25 Aug 2021 08:40
I find the discussion very interesting, but I always wonder how much effort should actually be put into protective measures for furniture that is cheap by design and meant to be functional rather than an heirloom.
LUISABEL schrieb:
For UV protection, indoor measures like curtains or UV-protective films on windows are recommended
That’s certainly sensible, but honestly: Malm is not exactly a solid wood designer piece. Of course, I understand the desire for protection, but maybe you should also accept that furniture ages and shows signs of wear over time – that’s part of its life cycle.
Just my provocative opinion: sometimes it actually adds to the atmosphere, especially with Malm, when scratches and slight discoloration are visible, as long as the furniture still functions. But if anyone objects, they can always spray, wax, or laminate it if that helps 🙂
Hannes
25 Aug 2021 11:23
Malm lacquered or melamine coated?
You use coasters and immediately wipe up any liquids with a soft cloth.
No harsh cleaners, no wax.
Done.
