I recently bought some Malm furniture from Ikea, mainly dressers and nightstands. Since these pieces are made of particleboard with a laminate finish, I’m thinking about the best way to protect them from water damage. Specifically, I want to prevent water stains, moisture from spilled liquids, or condensation without affecting the appearance or functionality. Are there special sealants, care products, or effective protective measures you would recommend? Maybe you also have practical everyday tips based on your experience?
I look forward to your opinions and advice.
to protect Malm furniture from water damage, the most important measure is to keep the surface as waterproof as possible. Since Malm is mainly made of particleboard with a foil veneer, you cannot simply treat this surface with paint or varnish because it is often unsuitable for such coatings, which can cause changes in appearance or poor adhesion.
What I would recommend:
1. Use water-repellent coasters or felt pads under vases or glasses to avoid direct contact with moisture.
2. In case of spills: wipe up immediately, as the foil can swell if exposed to moisture for too long.
3. If you want to make the surface somewhat more sealed, special furniture waxes or beeswax pastes can be applied thinly. While they do not create a perfect seal, they can increase the surface’s resistance to moisture.
4. It is also common, for example with bedside tables, to place a plastic or transparent film protector on top.
One important question: Are the furniture pieces located in a bathroom or other areas with high humidity? This would increase the risk.
The most important thing is: Do not leave water standing on the surface for a long time. Although the foil is resistant, it is not waterproof against prolonged moisture.
Domau0 schrieb:
For spilled liquids: wipe immediately, as the surface film can swell if left wet for too long.Exactly, that’s true! 🙂
I always imagine my Malm dresser with a nice tray or a non-slip mat on top – not only does it look stylish, but it also practically prevents stains. And if you spill coffee or water, the surface is easy to clean.
I also love having small decorative plants on my furniture, but I always use small coasters under the pots. Such a spacer protects the surface from moisture damage – that’s really invaluable.
Sometimes a little routine goes a long way to avoiding a lot of trouble.
I can fully agree with the advice about protective underlays. Additionally, I want to emphasize that pine furniture may seem sturdy, but especially with heavy use, moisture can actually cause damage. In my experience, special furniture care products that create a water-repellent layer without changing the appearance work well—such as furniture oil for veneers or special furniture wax pastes.
It is important to test the care product on an inconspicuous spot first, to avoid changes in color or differences in gloss. This treatment should be repeated regularly to help keep the furniture more resistant.
One more tip: for open drawers, be aware that moisture can also penetrate from the inside, so wet items should not be placed inside.
How do you mainly use the furniture? In a bedroom or a more humid room?
GiRoyce schrieb:
How do you mainly use the furniture? In the bedroom or a more humid room?Thanks for asking! The Malm dressers and nightstands are in my bedroom, which sometimes gets a bit humid, especially in winter when I ventilate. So far, I have avoided placing wet items like flowers there, but I tend to put my water jug or wine glasses on the nightstand. It’s more of an everyday scenario with some risk of moisture, but nothing as humid as a bathroom.
How important do you think regular use of these care products is? I was worried that it might damage the foil covering.
